01-14-2016, 04:42 PM   #1
kingkong's Avatar
Pentax K30 return from repair center
the unit will not power up with battery inserted,
after $170 in repairs it does now, was told release switch and diaphragm control block needed to be replaced.
i was using the original pentax battery, i just tried using the dek aftermarket battery and no luck, will not power up, however i bought the knockoff aa battery holder and it works with that though, has anyone else here have this experience with their K30 as well ???
thanks
01-14-2016, 08:39 PM - 1 Like   #2
ramseybuckeye's Avatar
I'm not following your story, was it repaired because it would not power up and still does not, or did they fix it? Sounds like worn out batteries. I also had the diaphragm control block replaced on my K-30 under extended warranty, it took forever (I was caught in the CRIS to Precision fiasco, but it was a good repair..
battery, camera, k30, pentax, pentax help, pentax k30 return, photography, power, return from repair, troubleshooting
DLSR Repair Center Reviews pureluck Pentax DSLR Discussion 12 07-27-2011 05:44 PM
Suggestion Repair center reviews pureluck Site Suggestions and Help 3 07-15-2011 12:36 PM
W60-third repair return mrlebaron Pentax Compact Cameras 4 03-18-2010 07:19 PM
What does the repair center do? jrforman Pentax SLR Lens Discussion 5 05-12-2008 08:22 PM
img from DA*16-50/2.8, is it "okay"? Or, return for repair? volosong Pentax SLR Lens Discussion 10 04-24-2008 11:30 AM
All times are GMT -7. The time now is 06:51 PM. | See also: NikonForums.com, part of our network of photo forums!
