01-20-2016, 08:10 PM   #1
IgorZ's Avatar
Carl Zeiss 50mm 2.8
Hi,
Just got a Carl Zeiss Jena Tessar 50mm 2.8 lens today, and was really surprised how small it is. It doesn't cover (don't know the proper scientific term) contact pins for the lens. Is that a problem? Or is it OK to walk around like that provided there is no rain or snow?
Thank you for your help!
01-20-2016, 08:30 PM   #2
Yeah, it's a wee one. Light leaks through the adapter are a possibility with a standard flush-mount (infinity-focus allowing) m42 adapter. I use a third-party one with the spring removed, which makes it even more likely, and I also have to be careful not to twist it out when focusing since it is just a friction fit without the spring in the adapter. With other old lenses that "lacked base" like this, I've used a big rubber washer around the bottom to gain some friction and block light, but that one is so small I found it easier to make a "skirt" for it out of black gaffer tape that hangs off a bit to block light around the base (folded back on itself so it isn't sticky on the camera base, although good quality gaffer tape won't leave a residue if you do stick it right on there). I'm sure there is a better solution, that's what I had on hand.
01-20-2016, 09:42 PM   #3
tromboads's Avatar
Nice little Tessars they are too
I used one on a K10 and K5, light leaks never worried me.
Have fun with it.
01-20-2016, 10:38 PM   #4
osv
i use a stretchy black hairband for light leaks, not sure if it'll stay in position in this situation.
01-20-2016, 11:10 PM   #5
It's actually an interesting lens. Although not as sharp as its 1.8 east german relatives (CZJ Pancolar and Pentacon/Meyer Orestor), it has quite a signature. I especially like to use it during the gloomy winter days. Its rendering seems to give it something extra.
01-21-2016, 07:14 AM   #6
IgorZ's Avatar
Thank you for all the advice! I must admit I haven't thought of light leaking, I was more concerned about the elements...
01-21-2016, 08:59 AM   #7
QuoteOriginally posted by osv Quote
That sounds easy. Or maybe an o-ring of the right size.
QuoteOriginally posted by IgorZ Quote
If you are using an adapter without the spring where you leave it on the lens instead of in the body (which you would not typically do with the genuine Pentax version with the spring intact) -- you can see the one of the gaps in the top of the adapter is just about flush with the base of the lens, leaving a tiny sliver that is vulnerable to direct sunlight. I'm not sure I've seen leaks from this lens (and there may be more than one version -- mine is the chrome red T preset version), but definitely have from similar lenses that lacked base around the mount. (So I cover up that spot with something and be careful about the friction fit.)
01-26-2016, 06:42 AM   #8
You could do an empirical test by setting a high iso, and setting manual exposure to 30 seconds using a lens cap. Shine a torch around the lens-body interface during the exposure and check the results.
01-26-2016, 02:24 PM   #9
IgorZ's Avatar
Thanks ofr the suggestion! I will try that
01-29-2016, 02:44 PM   #10
I once owned an Exacta Varex IIb with a Tessar, it was one of the best four element, three group lenses.
01-29-2016, 06:51 PM   #11
IgorZ's Avatar
I haven't had a chance to shoot much with it, but I certainly like what I've seen so far... Feels interesting using a lens that's older than my dad...
50mm, camera, carl, carl zeiss 50mm, lens, pentax help, photography, troubleshooting, zeiss
Carl Zeiss Jena 28mm f 2,8 Manuel raffin Pentax SLR Lens Discussion 7 05-25-2015 03:39 PM
For Sale - Sold: Carl Zeiss Jena DDR 50mm f/2.8 jatrax Sold Items 6 02-25-2015 11:22 AM
Carl Zeiss 50mm f/2.8 Tessar M42 Goslett Pentax SLR Lens Discussion 2 08-11-2010 05:57 AM
All times are GMT -7. The time now is 01:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
