01-21-2016, 04:12 PM   #1
K-3 II Sensor Cleaning
I am looking to buy some supplies to clean my sensor, cannot find information about the k-3 ii sensor anywhere and am wondering if it has the exact same sensor as the K-3. I particularly want to know if it has the tin oxide coating so I know which type of cleaning solution to buy. Also, wondering if anyone has any experience using the digital survival kit with type 3 sensor swabs. I read somewhere that they work with either aps-c or ff sensors and for some reason they are a lot cheaper on amazon than type 2 which is what the brand recommends for aps-c sensors. Any help is appreciated!
01-21-2016, 04:28 PM   #2
QuoteOriginally posted by pic-nic Quote
Yup, same sensor as the K-3 if that helps.
This might also help:
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/109456-d...ml#post1128045
01-21-2016, 04:32 PM   #3
Oldbayrunner's Avatar
All you should really need is a rocket blower if you have the dust reduction turned on. I've yet to have to clean any of my sensor. These aren't Canikon..lol
01-21-2016, 07:56 PM   #4
dcshooter's Avatar
Skip the solution and just buy the Pentax O-ICK1 cleaning system. It uses a unique polymer pen to lift dust/grime right off. A bit pricey at $45, but much easier than dealing with fluids.
01-21-2016, 11:21 PM   #5
QuoteOriginally posted by dcshooter Quote
(I added bold)I still think that is the most awesome name ever for cleaning solution.
01-22-2016, 08:17 AM   #6
QuoteOriginally posted by Michaelina2 Quote
May I ask...
I bought the camera used, as an upgrade to my K-S2. I was digging in the menu and found the dust alert setting which does not exist on the k-s2. It showed a fair amount of sensor dust, and being the novice I am, I tried to use a cue tip with some lens solution on it (which I saw being used on a lynda.com tutorial). I definitely don't have top quality lens solution, so I believe it left streaks on the sensor because now the dust alert function shows even more marks on the sensor.
I am going to try using my rocket blaster, but just wanted to see what my options were because I really don't want to put the sensor at any more risk. The o-ick stick, in my opinion, doesn't look like it would really work for the streaks I mentioned before, plus it looks rather scary to use.
Thank you everyone!
01-22-2016, 08:31 AM   #7
dcshooter's Avatar
Hmm, for streaks, something like a lens pen would probably work well without fluid, but the tips tend to be round, so it wouldn't get into the corners. You might be able to fashion something by cutting the tip, though.
Supposedly Eclipse kits have been reformulated to make them all ITO safe, so that might be an option for you.
01-22-2016, 08:44 AM   #8
Did you also notice DUST REMOVAL in the same menu???? Thats no different than your KS2 except that its much quieter. It's too late now but it pays to read up on a product prior monkeying with it. Perhaps you should consider sending it off to have it professionally cleaned before you really screw things up like scratching your sensor.
aps-c, camera, ii, k-3, k-3 ii sensor, pentax help, photography, sensor, sensors, troubleshooting, type
Pentax K-3 II, K-S2 and Ricoh GR II need your help! Class A Pentax DSLR Discussion 5 12-25-2015 09:13 AM
K-3 II noticeably slower than K-5 II shooting manual bursts flonix Pentax K-3 24 09-17-2015 10:38 PM
Sensor noise on the K-5 II vs K-3 groovyg Pentax DSLR Discussion 24 12-18-2014 03:45 PM
Cleaning sensor - K-01 ranjitacharya Pentax K-01 2 11-09-2014 05:10 PM
k-3 sensor cleaning Britboy71 Troubleshooting and Beginner Help 4 04-23-2014 08:45 AM
All times are GMT -7. The time now is 01:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
