01-25-2016, 08:04 AM   #1
K3 Menu help
I'm digging into the programming of this cool little camera and I have a few questions..
Are the Program Line and PShift functions unique to Pentax or are these standard for all DSLR cameras? I think my confusion is about hyper-manual mode.
The Program Line has a drop down menu to select DOF, sport, etc. Under this menu what is “normal” and how is that different from “auto” and when should I use them? How does this affect the manual mode?
The menu under e-dial programming under manual has a menu to switch between Pline, TV shift and AV shift. When would I want to use these functions?
I'm sure I'll have more along the way.
Thanks for your help.
01-25-2016, 10:30 AM   #2
QuoteOriginally posted by iso Quote
P line just shifts the program line in one direction or another. For example, if the camera were to pick 1/100s F8 by default, turning the wheel might change that to 1/200s F5.6. However, if the lighting conditions change, both the shutter speed and aperture can still change accordingly.
Av shift, on the other hand, locks in a specific aperture value. Think of it as Av mode without having to move the mode dial. When you turn the e-dial, you'll change the aperture value chosen by the camera, and the camera will maintain that setting and only adjust the shutter speed as needed. Tv shift is the same as Av shift, except it locks in the shutter speed instead of the aperture.
Most manufacturers default the e-dials to P line shift when in P mode. The ability to lock in a shutter speed or aperture setting without changing the shooting mode is very convenient and unique to Pentax, at least among DSLRs.
01-28-2016, 07:37 AM   #3
iso
Adam, Thank you for your prompt reply.
camera, functions, k3 menu, line, menu, mode, pentax help, photography, program, shift, troubleshooting
K3 menu colour themes wissink Pentax K-3 3 05-22-2015 05:52 AM
Pentax K30 camera menu only in English or some asian languages seyjo Troubleshooting and Beginner Help 8 11-06-2014 11:26 AM
K3 MENU button PENFRED Pentax K-3 19 10-08-2014 01:06 PM
Help! Pentax Q10: Firmware update menu selection TofuTO Pentax Q 3 08-18-2014 05:47 PM
Need help with debug menu! outsider Pentax SLR Lens Discussion 10 02-15-2012 08:01 AM
All times are GMT -7. The time now is 01:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
