02-01-2016, 12:48 AM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by keanex Quote
very slight soft front focus at 1.8 when at -10
Your K-50's AF detector has a focus sensitivity of f/5.6 for all points. What that means is that the system will focus as well at f/5.6 maximum aperture as at f/1.8 despite the greater DOF at f/5.6. This is typical for consumer-level dSLRs regardless of brand. This works fine for lenses having modest maximum aperture, but may yield a fair number of OOF results when shooting wide open at f/2.8 and faster. The OOF results will be about evenly split between front/back focus.
Another thing to consider is that mechanical precision in the focus mechanism is poorer at distance than close up (one step of the motor has greater effect). Focus testing is generally done at about 20x or 30x the lens focal length unless some sort of internal focus is present requiring tests at both near and far. Your DA 50/1.8 is not such a lens. Testing should also be done using both near-to-point and far-to-point to account for mechanical lash.
You may want to attempt manual focus with magnified live view as a check. If you have similar issues with softness, the problem is not with the AF system.
02-01-2016, 01:30 AM   #17
Tuned my da 50 for my k5 yesterday. Used the mtfmapper software (free software) to generate a focus graph. All my lenses consistently shifted focus back when closing the apperture ... Took lots of shots to confirm. Only worked with PEF files DNG failed for some reason.
From previous experience distance also matters. You might require different adjustments for different distances to subject.
02-01-2016, 06:14 AM   #18
Wow, this forum is great! Thanks for all of the information!
02-11-2016, 06:13 AM   #19
Alright - sorry to keep going with this but it seems there's still a very slight soft front focus at 1.8 when at -10. I could live with it, but I know that in the back of my head I'll always worry about potential "focus drift" or something. Let's see how support is!
I've never read anything about the focus drift on any of Pentax's cameras except the K-5. I own a K30 which is the same guts as the K50 in a different body - and mine has been very consistent and reliable. If you had the opportunities to buy one of those extended warranties from Pentax for $20-30 then that should cover them servicing it to work with those lenses you have.
By the way you haven't mentioned which lens you are shooting with at 1.8? If it is the 50 1.8 - that is a great lens especially for the price, but I would bet that it is soft in that area wide open. I've shot with that lens on boy my K5s and K5II and K30 and K-X and all had the same result wide open. 2.0 for that lens and the FA 50 1.4 is perfect for good blur and sharpness.
For what it is worth.
02-12-2016, 10:11 AM   #20
QuoteOriginally posted by zbrueningsen Quote
Yeah it's a 50/1.8, seems a bit soft at 1.8
02-13-2016, 05:26 PM   #21
I think it could be the softness. I used the 50 1.8 for a while and I thought I had a focusing problem, but it is soft wide open. Stop it down into the 2.4-2.8 range and see how much it improves. Also try it on Live View to compare the images between that and viewfinder focus. Your Live View should be dead on, and at 1.8 you should be able to see how it should look. So if it is soft there, the lens is a bit soft wide open.
I really love the 50 1.8, its rendering and color and sharpness (stopped down) are excellent for a sub $100 prime. However, it is the least expensive Pentax lens sold. Hope this helps a bit.
adjustment, camera, focus, front, object, pentax help, photography, subjects, tripod, troubleshooting
How to Adjust Infinity Focus - DA 50-200 WR Just1MoreDave Pentax SLR Lens Discussion 3 10-11-2013 03:44 PM
How to adjust infinity focus on Takumar 35MM 3.5 bornamachine Troubleshooting and Beginner Help 20 06-30-2013 01:54 AM
Debug Mode to adjust for Back Focus merengue Pentax K-5 9 07-18-2012 06:14 PM
How to adjust for FF BF SlickYamaha Troubleshooting and Beginner Help 3 08-23-2011 03:03 PM
Question: How to adjust focus stop on 3M 5CA 500mm mirror lens GibbyTheMole Pentax SLR Lens Discussion 2 06-07-2011 07:35 AM
All times are GMT -7. The time now is 06:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
