01-31-2016, 10:24 AM   #1
Vivitar 28/1.9 barrel wobble
I have recently purchased a Vivitar 28/1.9 in good condition. The glass is without marks, the aperture is snappy and the lens is also in good condition cosmetically. However, the lens barrel has a pronounced wobble when the focussing ring is turned towards the closest focussing position. From about 0,5 meters till infinity there is no wobble whatsoever. I suspect that the wobble is related to the floating element that comes into action when the focussing ring is turned towards closest focus. Is this normal for this lens?
I am grateful for any advice on this matter!
01-31-2016, 11:03 AM   #2
Not a Number's Avatar
It maybe that the grease has dried out and simply no longer damps out the wobble as it should. The lens may simply need to be cleaned and re-lubricated.
01-31-2016, 11:16 AM   #3
dms
Mine has a noticable (sudden) reduction in resistance (like a slipage) over a small distance range--near the minimum focus distance.But no wobble. Purchased used and never handled one when they were new, but I assume this is age related.
01-31-2016, 11:36 AM   #4
It is supposed to have a change there (not sure it is supposed to be a "wobble" though). As mentioned, part of the macro function -- I think one of the elements actually changes direction, can't remember, but it has a definite "hitch" that is normal and part of the design...
01-31-2016, 12:36 PM   #5
Thank you very much for your helpful comments! My copy has a wobble near the minimum focus distance, I also observe that the aperture blades move when I move the barrel/provoke wobble. So something is wrong with my lens.
01-31-2016, 12:45 PM   #6
QuoteOriginally posted by bjolester Quote
That may be normal also -- do they just close slightly? Although weird designs like that do provoke people to attempt "repairs" that are not needed, so it could be messed up from the last person it confused...
01-31-2016, 01:06 PM   #7
Yes, the aperture blades close slightly when I move the lens barrel from side to side at minimum focus distance. There are luckily no signs of any "hobbyist repairs" anywhere on the lens. It looks as if I am the first confused owner...
01-31-2016, 01:20 PM   #8
My guess is that is normal as long as it is consistent.
aperture, barrel, camera, condition, lens, pentax help, photography, troubleshooting, vivitar, vivitar 28/1.9 barrel, wobble
Sigma 17-50mm 2.8 barrel wobble? wowarning Pentax SLR Lens Discussion 5 06-04-2014 09:26 AM
measuring DA 16-45mm barrel wobble tibbitts Pentax SLR Lens Discussion 7 02-24-2014 09:38 AM
Vivitar Series 1 28/1.9: Aperture gets stuck & infinity mark is off Boris_Akunin Pentax SLR Lens Discussion 5 09-30-2013 04:03 AM
SMC Pentax 1:2/28, Super-Takumar 1:35/135, Vivitar 1:1,9/35 octavmandru Pentax SLR Lens Discussion 15 04-02-2009 11:46 AM
Does DA70 barrel wobble? selar Pentax SLR Lens Discussion 2 03-12-2008 05:40 AM
All times are GMT -7. The time now is 12:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
