02-02-2016, 06:22 AM   #1
Problem with colours
Hi
My camera is a K-r.
Lately is taking pictures as the one i uploaded.
I need to take some pictures or turn off/on the camera for taking pictures in the right way.
Don't know the problem.
Besides, when i can't use some lenses, a 50mm and a 70-200mm, manual both.
With the last one listed it makes some noise and i can't take pictures.
Can you help me?
PENTAX K-r  Photo
02-02-2016, 07:34 AM   #2
Bruce Clark's Avatar
Tough one. I would suspect a card problem. If not the card itself then some issue with the camera writing to the card. Reformat card in the camera after saving all your photos to a computer drive. Or get a new card.
02-02-2016, 07:47 AM   #3
But when i use the live view i don't see clearly the object i'm registering.
Sometimes i only see a pink frame. That's why i need to take many pictures until i get the right one.
With the 200mm lenses i can't even shoot.
Maybe i'll upload a video to clarify.
02-02-2016, 09:20 AM   #4
enoeske's Avatar
QuoteOriginally posted by jfca283 Quote
if you're seeing the same thing when in LiveView mode, then I suspect the sensor has gone bad. You'll have to send it in for repair.
02-02-2016, 11:53 AM   #5
aleonx3's Avatar
Couple of things I see from the EXIF of the picture. Is there any reason why you are auto-bracketing the shots? also, any particular reason you use 'spot metering' for landscape photos? When you take picture with Liveview, do you see any problems before you capture the picture (press shutter release)? I would expect most likely the problem with the memory card based on the photo. But then again, there could be other things as well.
If you pressed or change something you are not sure of, the best way to get out of it is to reset the camera and start over again to see if you can replicate the problem.
camera, pentax help, photography, pictures, troubleshooting
Abstract Playing with colours tehSancho Post Your Photos! 2 11-13-2010 09:36 PM
Landscape Badlands with Fall Colours Bobe416 Post Your Photos! 7 10-17-2010 05:38 AM
Is Lightroom messing with my colours? gfonso Digital Processing, Software, and Printing 10 11-14-2009 01:56 PM
Nature Autumn Colours with the DA35 kevinschoenmakers Post Your Photos! 2 11-09-2009 10:53 AM
Pentax warm, vivid colours on k200d with no PP netuser Photographic Technique 7 12-15-2008 06:36 AM
All times are GMT -7. The time now is 09:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
