02-10-2016, 02:30 PM   #31
GUB
GUB's Avatar
Well, the more northern parts of Scotland are the best for UK viewing, as I understand it - though we *can* occasionally see it from areas of Northumberland, just a little further north of where I live... But it's cold and wet here right now - so my offer of lenses, Blu-Tak and spearmint gum stands!
Yes your weather has made it on the news down here
---------- Post added 02-11-16 at 10:42 AM ----------
QuoteOriginally posted by DagT Quote
No, this is NOT Newton rings. Newton rings are uneven and require contact between two surfaces. The phenomena you see in these pictures show rings distributed form the optical axis being gradially closer together. You get this from two parallel surfaces being spaced apart, often in UV filter, and only when the light is (almost) monochromatic, like in the Aurora. The effect is related to socalled Fabry-Perot filtering. You can see an explanation here
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/fabry.html
and a picture of the rings here as well as more explanation here:
https://en.wikipedia.org/wiki/Fabry–Pérot_interferometer
PS: Take the UV filter off and try again :-)
Great stuff -- it is fascinating.
I am trying to get my head around the resulting optics--- If you looked through the filter with your naked eye at the aurora, would the effect be visible? (filter at hand length)
02-10-2016, 02:49 PM   #32
It should be, but that depends on the contrast. I used a high quality Fabry-Perot for my masters degree in optics, and then the patterns were clearly visible, but the UV-filter is noe very high quality as an interferometer so the contrast may be low.
A lot of parameters come in play here. Very good filters are plane, which would increase the effect, but if the anti reflection coating is good at the relevant wavelength it will reduce the effect.
02-10-2016, 03:12 PM   #33
GUB
GUB's Avatar
Probably a dumb question but would anti reflective coating affect the internal reflection here.
02-10-2016, 03:21 PM   #34
I shoot lots of aurora with my K-5, but I have never gotten those rings. Although I never tried the Tamron 17-50/2.8, I use lots of other lenses for aurora. Sigma 18-35/1,8, Tamron 10-24, Samyang 8/3,5, and sometimes Pentax 18-55 WR and 18-135 WR.
That leads me to think it must be lens related.
02-10-2016, 03:23 PM   #35
GUB
GUB's Avatar
QuoteOriginally posted by Simen1 Quote
Do you use a filter?
02-10-2016, 03:28 PM   #36
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by GUB Quote
Did we determine that the OP used a filter? I can't recall...
02-10-2016, 03:45 PM   #37
GUB
GUB's Avatar
He didn't say. From what DagT says it pretty well has to be the filter.
02-10-2016, 03:55 PM   #38
clackers's Avatar
Yep, there's a bin right over there! 😀
02-10-2016, 03:55 PM   #39
Senior Moderator
BigMackCam's Avatar
Just pass them right over here, folks... to my home for unloved UV filters...
02-10-2016, 04:07 PM   #40
No, I never use filters when shooting aurora.
02-10-2016, 04:35 PM   #41
GUB
GUB's Avatar
OK I might be stubborn as a pig but is there any reason why this wouldn't happen at the sensor array filters? After all they would be built to a higher precision than an aftermarket one. And it would keep me happier about the sharpness of the image.
It would mean of course that Simen1 should get them though.
02-10-2016, 04:40 PM   #42
Senior Moderator
BigMackCam's Avatar
Film... remember the *film*...
02-10-2016, 04:55 PM   #43
GUB
GUB's Avatar
Yeah yeah I know but the only image I saw from film was bigger and softer.
And there is a uv filter layer on film.
Hopefully DagT will get back -- he has been playing with this effect.
02-10-2016, 06:12 PM   #44
clackers's Avatar
That's a quite a yard of strays you've got there!
The 49mm ones are so cute ... those 77mm ones, everyone thinks they're great but they need a lot of exercise or they take it out on your couches. ☺
02-10-2016, 06:24 PM - 1 Like   #45
Senior Moderator
BigMackCam's Avatar
Send just ten bucks a month and you can adopt a filter of your choice. You'll receive regular photos taken with your adopted filter and a hand-written letter keeping you informed of their progress...
28mm, air, aurora, blur, camera, circles, distortions, effect, explanation, filter, interference, lens, light, manual, newton, night, pattern, pentax help, photography, photos, rings, sensor, source, surfaces, troubleshooting, uv
Weird line on photos. Where's the problem? kmhtax Troubleshooting and Beginner Help 22 03-19-2014 10:35 PM
Weird night behavior of pentax-a 50/1.7? malenisjaj Pentax SLR Lens Discussion 9 03-12-2014 04:23 PM
Ricoh GR circular rings artifacts in the pictures seyfer Ricoh GR 6 09-05-2013 07:54 AM
16-45 weird night flare? SMeK Troubleshooting and Beginner Help 18 12-24-2010 06:04 AM
Some weird weather last night Heinrich Lohmann Post Your Photos! 16 06-26-2007 09:04 PM
All times are GMT -7. The time now is 08:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
