02-11-2016, 01:10 PM   #1
K1000 K-mount issue
Hey guys...I just this morning received a K1000 to add to my Pentax M42 collections. I guess this makes me a K-mount virgin. Anyway, the camera came with two lenses: a Pentax-A 50mm f/2, and a Sigma 100-200mm zoom f/4.5 Macro.
The Sigma mounts right up, twists and locks to the frame of the camera....the 50mm will not. It slots up (lining up the dots) but will not turn at all.
I'm certain there is a trip lever or something inside the lens I need to release somehow, but don't know where to start.
Any help is welcomed!
Thanks,
Sam
02-11-2016, 01:18 PM   #2
john.margetts's Avatar
No trip lever in a K- mount. I suspect your lens is damaged. Carefully compare the bayonet end of both lenses, looking for very slight differences.
02-11-2016, 01:47 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by yosemitesamiam Quote
QuoteOriginally posted by john.margetts Quote
What he said...
If it will not turn, do not force it. It is very likely that one of the couplings (there are two) is bent out of alignment.
02-11-2016, 01:55 PM   #4
Yeah...it does appear (using a 1/100ths metal ruler) that one flange is out of spec with the rest...and with the other lens..hmmm...junk I suppose.
---------- Post added 02-11-2016 at 12:56 PM ----------
What he said...
Oh...two? I was looking at the three flanges...
---------- Post added 02-11-2016 at 01:05 PM ----------
Anyway, safer to count my loses on that particular lens I think. Not certain a 50mm f/2 is worth losing sleep over.
Thanks guys.
02-11-2016, 03:17 PM   #5
Does the sigma lens require a k-bajonette adapter to be mounted on the body? Maybe it is still connected to the body and this won't allow you to mount the 50mm.
02-11-2016, 03:53 PM   #6
QuoteOriginally posted by gabro822 Quote
I wish it were that easy. :/
The sigma is made for k mount. The camera is bare camera. I think it's toast.
02-11-2016, 04:30 PM   #7
Can you post some pictures of the lens and camera's mounts?
02-11-2016, 06:36 PM   #8
Sure thing! Here are a few. One of the camera, one of each lens, and then one front and back of the Pentax lens, as well as the side view (for Pentax K) on the Sigma...
Thanks! It would be great to not have to shop for another lens...!
02-11-2016, 07:00 PM   #9
monochrome's Avatar
If you're going to trash an A50/2, which can be a fine, sharp normal lens, consider the use of two needle nose pliers and judicious bending of the bad flange. You can't make it worse, I don't think.
02-12-2016, 05:22 AM   #10
From these pictures, everything seems ok with the lens mount. Does the lens face correctly the camera mount, or is there a little gap? If the problem is just that you can't turn the lens, try to see if is the lens aperture lever that can't be moved or the camera's one. Is the inner plastic bajonette at the same level of the other mount's components (maybe it grip with the mirror and you can't turn). Sorry for real basic advices, but is a really strange problem...
50mm, camera, k-mount, k1000, pentax, pentax help, photography, pm, post, sigma, troubleshooting
For Sale - Sold: Rare Vivitar K mount 24mm f2.0 manual focus lens w/issue-photos added 17dew Sold Items 5 11-23-2015 08:30 AM
Sears 80-200mm PK-mount lens doesn't mount on K1000 kylemsguy Pentax SLR Lens Discussion 8 09-19-2013 11:44 AM
k-mount issue photoman1 Pentax DSLR Discussion 7 09-22-2012 12:42 PM
Pentax Auto K Mount teleconverter on Manual K1000 body/lens ? cajnuBlues Pentax SLR Lens Discussion 3 11-18-2010 02:58 PM
For Sale - Sold: Free K mount stuff, parts unit K1000 Rustyoldbug Sold Items 4 05-31-2009 02:11 PM
All times are GMT -7. The time now is 09:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
