"F _ _" indicates the lens and camera are not communicating.
Originally posted by KDD Try turn on using Aperture ring??
'A' lens, so should not matter, assuming aperture ring is in 'A' position.
As Bertwert says clean the lens and camera contacts. Check the lens mount to make sure the screws are all tight. I have seen some reports of sigma lens mounts being slightly misaligned. THis can cause the contacts to be off just enough to miss contact. Check that the lens mount has no play in it. Try turning the lens a bit after it is on the camera to see if there is any play in the connection.
