02-15-2016, 02:03 AM   #1
JimD's Avatar
Exif Reader
I downloaded Exiftool(k) by Phil Harvey onto my desktop a few years back and it's worked ok ever since with my K5 by dragging and dropping files to the icon.
After taking my K3ii out for the first time yesterday, I did the same. The info that came up was very confusing. After what must have been 5000 -6000 numbers under AE, Flash and Slave Flash metering segments there was not the amount of info that is displayed on my K5 shots. Not even the camera model or make. It gave the manufacture date and a serial number.
I thought initially that, as it was loaded onto my desktop 4-5 years ago, it wouldn't recognise the K3ii, the reader would need updating.
I deleted the program and downloaded the latest version, that was created on 22 Jan 2016, but the same happened. The K5 files read perfectly.
I put the same K3ii files into the 'Check shutter count and manufacture date' resource on the forum and all of the info displayed perfectly.
Any ideas or solutions ?
02-15-2016, 06:54 AM   #2
Not a Number's Avatar
Odds are the tool doesn't take into account changes in the files for Pixel-Shift information. It's probably a change in the byte offsets. I would contact the developer through the support forums.
ExifTool Forum - Index
https://sourceforge.net/projects/exiftool/support?source=navbar
02-15-2016, 03:59 PM   #3
Des
Des's Avatar
I just checked an image taken with my K-3 and Exiftool is reading all the data correctly. It must be something particular to the K-3ii - @NotaNumber is probably right.
I mostly use the free program Picture Information Extractor these days: Picture Information Extractor - EXIF IPTC | Picmeta Systems It captures all the information I want (including shutter count). Maybe try that.
02-15-2016, 04:57 PM   #4
amoringello's Avatar
Works fine for my K3 and K3ii.
I have exiftool ver 9.02 (had it for some time now)
--- the following is an example of just the first tiny bit of info ----
exiftool _AMP3115.DNG | more
ExifTool Version Number : 9.02
File Name : _AMP3115.DNG
Directory : .
File Size : 27 MB
File Modification Date/Time : 2016:02:14 16:43:59-05:00
File Access Date/Time : 2016:02:15 18:56:58-05:00
File Permissions : rw-------
File Type : DNG
MIME Type : image/x-adobe-dng
Exif Byte Order : Little-endian (Intel, II)
Make : RICOH IMAGING COMPANY, LTD.
Camera Model Name : PENTAX K-3 II
Orientation : Horizontal (normal)
Software : PENTAX K-3 II Ver. 1.00
Modify Date : 2016:02:14 14:11:02
Artist : Anthony J Moringello
Image Width : 6080
Image Height : 4032
Bits Per Sample : 14
Compression : JPEG
Photometric Interpretation : Color Filter Array
Strip Offsets : 211296
Samples Per Pixel : 1
Rows Per Strip : 4032
Strip Byte Counts : 25859049
X Resolution : 300
Y Resolution : 300
Planar Configuration : Chunky
Resolution Unit : inches
CFA Repeat Pattern Dim : 2 2
CFA Pattern 2 : 0 1 1 2
CFA Layout : Rectangular
Black Level Repeat Dim : 2 2
Black Level : 0 1 0 1
White Level : 16317
Default Scale : 1 1
Default Crop Origin : 6 12
Default Crop Size : 6016 4000
02-15-2016, 11:45 PM   #5
JimD's Avatar
Thanks! But this is a bit beyond me.
QuoteOriginally posted by Des Quote
Thanks. I've installed it and it works fine
QuoteOriginally posted by amoringello Quote
Directory : .
File Size : 27 MB
File Type : DNG
Image Width : 6080
Image Height : 4032
Compression : JPEG
X Resolution : 300
Y Resolution : 300
White Level : 16317
Default Scale : 1 1
The latest version I've downloaded is 10.1.0 dated 22nd Jan 2016. I've tried it on 3 different computers with exactly the same results.
02-16-2016, 01:06 AM   #6
QuoteOriginally posted by JimD Quote
Did you try version 9.02? What files are you using - PEF, DNG or JPEG? Try different formats.
If it works on DNG and JPEG but not PEF in version 10.10 then post a message on the developers support forum and give them sample files when requested so they can fix the problem.
02-16-2016, 02:31 AM   #7
Des
Des's Avatar
Good to hear. PIE is a great little program. It can sort your photos by lens, and rename files according to a specified scheme, amongst many other things.
02-16-2016, 06:34 AM   #8
JimD's Avatar
I don't know if the previous version I had was 9.02 but that not working was what prompted me to install the latest.
Neither DNG or JPEGs work
02-16-2016, 08:27 AM   #9
Well really the only way to resolve the problem is to contact the developer:
If you have any comments, suggestions or questions, please post to the ExifTool Forum so other people may benefit from your experiences. (I check the forum at least as often as my email.) Otherwise, if you must contact me directly, my e-mail address is on the first line of the README file in the full distribution. Thanks. - Phil Harvey
The entire archive of the productions versions is below You need to install perl on your computer to run them or a tool to create an executable file for PC or Mac.
Index of /authors/id/E/EX/EXIFTOOL
CNET version 9.35 for Windows:
ExifTool - Free download and software reviews - CNET Download.com
You could open a bug ticket but your best bet is the forums.
https://rt.cpan.org/Public/Dist/Display.html?Name=Image-ExifTool
02-17-2016, 05:53 PM   #10
I am running ExifTool v9.76 and have not encountered any problems with K-3 files (DNG or PEF) from my camera or the K-3II files I have downloaded, though I did not do a thorough go through on the K-3II files. My expectations would be that it would simply fail-over to numeric values where mappings were not known for new cameras/lenses and not display for unknown tags.
02-17-2016, 11:40 PM   #11
Just downloaded the windows exe for ExifTool v10.11 and it works as expected for K-3II DNG and -k -g -a options. All four images are accounted for in the maker notes.
Here is a snippet from the begining of the MakerNotes section:
Code:
---- MakerNotes ----
Pentax Version : 11.6.1.0
Pentax Model Type : 0
Preview Image Size : 720x480
Preview Image Length : 54113
Preview Image Start : 85664
Pentax Model ID : K-3 II
Date : 2015:07:12
Time : 15:17:41
Quality : RAW (pixel shift enabled)
Flash Mode : Off, Did not fire; Internal
Focus Mode : Contrast-detect (Focus-priority)
AF Point Selected : None; Single Point
AF Points In Focus : (none)
Exposure Time : 1/250
F Number : 7.1
ISO : 100
Exposure Compensation : +0.3
Metering Mode : Multi-segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Auto
Focal Length : 78.0 mm
Saturation : 0 (normal)
Contrast : +1 (med high)
Sharpness : +1 (med hard)
DSP Firmware Version : 1.00.00.01
Effective LV : 14.1
Picture Mode : Program (HyP); 1/3 EV steps
Drive Mode : Single-frame; Self-timer (12 s); Shutter Butto
n; Single Exposure
Color Space : sRGB
Data Scaling : 8192
Preview Image Borders : 0 0 0 0
Lens Type : smc PENTAX-DA 18-135mm F3.5-5.6 ED AL [IF] DC
WR
Note that the pixel shift state is captured as are the appropriate camera and lens types.
02-17-2016, 11:50 PM   #12
The tag file for Pentax (last updated 7 Jan 2016) has the K3ii listed.
Version 10.10 was dated 22 Jan 2016.
camera, date, desktop, files, flash, info, k5, manufacture, pentax help, perfectly, photography, reader, troubleshooting
O-GPS1 and your EXIF data - When the GPS is on, it strips data from the EXIF? Sagitta Troubleshooting and Beginner Help 17 11-23-2016 02:25 AM
Viewing EXIF details on ipad? JohnnyBoy Digital Processing, Software, and Printing 6 07-18-2015 01:41 AM
Pentax K5 card reader failure mickeymon Troubleshooting and Beginner Help 7 01-06-2015 07:54 AM
DA-HD 55-300 & Apple EXIF reader K-Three Digital Processing, Software, and Printing 3 11-24-2014 12:36 AM
EXIF reader ChrisA Pentax K-3 3 05-29-2014 07:23 AM
All times are GMT -7. The time now is 08:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
