Hi,
I just got in a set of 3 extension tubes, and was messing around with them and my K-r with my DA 35mm lens. I originally thought, "Ok, this'll be easy.", but then I realized that the DA 35mm lens doesn't have an auto/manual switch and also doesn't have an aperture ring.
So then I figured that maybe if I put the K-r into M mode and used the green button, the K-r would automatically figure out the settings, but that didn't work. All the pics I took were seriously under-exposed.
So the first question I have is: Using a lens like the DA 35mm, which doesn't have an auto/manual switch for exposure, and also doesn't have an aperture ring, is it possible to use such a lens with an extension tube with the K-r? And, if so, how?
I guess that if the answer to that question is "no", then would using an SMC-M lens or an SMC-A lens that is not set to "A" work, and if so, how? Would I use that with the K-r in "M" mode then stop down the lens anduse the green button to get the K-r to figure out exposure?
Thanks,
Jim
