02-20-2016, 05:18 AM   #1
calvert's Avatar
Tamron 28 - 300
I have just purchased, via e-bay, a Tamron AF Aspherical LD (IF) 28-300 for use with my Pentax cameras. I live in the U.K. and the lens came from the U.S.A. It is a 72mm filter size. The equivalent European lens has a 62mm filter and differs in appearance. This is not a great problem but I can only find the Euro User Manual on line. Most things I can figure out, no problem but a couple of issues intrigue me.
1) There is a little inverted triangle mark slightly to the left of the Diamond shaped mark for setting "A" or the aperture. It's a bit like the offset infra-red focus mark often found on manual lenses but it is in totally the wrong place for that. What does it signify ??
2) I feel I am not getting the best out of the "Macro" facility, am I missing a trick somewhere, any advice or a link to the U.S. user manual would be most appreciated.
Cheers.
02-20-2016, 06:37 AM - 1 Like   #2
not sure if this is what you are looking for
http://www.tamron-usa.com/assets/pdfs/A06.pdf
maybe it will help
good luck
02-20-2016, 08:48 AM   #3
calvert's Avatar
Thanks..
---------- Post added 02-20-16 at 08:51 AM ----------
Thanks..One mystery solved.
camera, filter, lens, mark, pentax help, photography, tamron, troubleshooting, user
Tamron 28-300 IQ Samples and Questions DavidSKAF3 Pentax SLR Lens Discussion 5 12-11-2014 06:36 PM
Pentax DA 55-300 WR vs Tamron 28-300 TzalamChadash Pentax SLR Lens Discussion 21 05-06-2014 07:48 PM
Tamron 70-300 vs. Tamron 28-300 Richie1978 Pentax SLR Lens Discussion 3 10-28-2009 02:26 PM
All times are GMT -7. The time now is 10:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
