Originally posted by stevebrot Oh...so you meant to say that you usually use spot metering and TAv mode when shooting wildlife. You might also want to consider using matrix metering and setting it to follow the focus point (menu/C1/5)
Yes, I have also used it or Center Weighted Spot to shoot individuals, and have used Multi-Segment metering for groups or landscape. If using Spot AF mode, I usually use Spot Metering mode, obviously I am already linked at that point. As you say, matrix metering is an option, depending on how you want to shoot.
---------- Post added 02-25-16 at 03:23 PM ----------
Originally posted by house Tav mode is risky in bright lighting. As mentioned above you risk over exposing. Make sure to keep an eye on the exposure meeter in the viewfinder.
I have resorted to -EV when bright light is present using TAV mode. It is effective in bringing down the ISO and giving a sensible image exposure while counteracting the bright light if it is present.
