03-02-2016, 05:02 PM   #16
Blacknight659's Avatar
Meta data shows exposure is manual... also, spot metering could cause some issue depending on what you point the camera at.
03-02-2016, 05:36 PM   #17
QuoteOriginally posted by Blacknight659 Quote
I tried it on all three metering modes earlier and had the same results with all three.
---------- Post added 03-02-16 at 05:59 PM ----------
Well I guess I can just return the 77 and get a k3. Was not my plan but I don't see much other choice at this point.
03-03-2016, 07:07 AM   #18
You definitely have something going on with the camera.
I recommend taking it to a shop. If you can't:
- look into servicing the mode dial. Perhaps it isn't switching between modes. Recent thread here talked about someone using WD-40 (not the hardware store kind but electrical, google it) GR mode dial and menu glitch - PentaxForums.com
- upgrade the firmware
- try a different battery (rule out power issue)
- try a different memory card (why not)
- Clean the sensor / mirror (could have an issue getting light to the light meter.
- Make try different metering modes (center weighted, scene, etc)
>>>> I would disable attached to focus point setting<<<<
Good luck
aperture, camera, da, fa, k-50, lens, lv, meta data, meter, pentax help, photography, pm, post, shutter, troubleshooting, vf
K-500 metering trouble with Kit lens HHHkumar Troubleshooting and Beginner Help 4 06-21-2015 12:31 AM
People Easter with the FA 77 K McCall Post Your Photos! 7 04-21-2014 03:25 PM
Metering trouble with Sigma 70-300 and K2000 veegish Pentax SLR Lens Discussion 8 10-27-2009 06:15 PM
Trouble with my FA 80 - 320 4.5/5.6..... UpNorth Pentax SLR Lens Discussion 5 01-11-2009 10:59 AM
All times are GMT -7. The time now is 08:04 PM. | See also: NikonForums.com, part of our network of photo forums!
