03-04-2016, 08:33 PM   #1
BirdDude007's Avatar
Help .....SDM in 50-135mm failed!!!!!
Like the title says, i tried the search funtion in these forums but no luck there. I see there may be some quick fixes, and i even see there is a way to make it so i can just use the screw drive which is what i want. So ant and all advice and options will be appreciated
I have a K5
03-04-2016, 08:37 PM   #2
LeDave's Avatar
That's unfortunate! How long have you had the lens? I would do quick fixes over screw drive, I do quick fixes on my 5 year old DA* 16-50 for a year and a half since it failed. I don't want to do screwdrive yet because I like the light squeekie noise over hearing loud gear wheels moving back and forth. My 16-50 might actually came alive again without quick fixes because it's been a week since I don't have to quick fix it.
EDIT: The easiest quick fix is to hold the AF button down for a couple of seconds then let go, then repeat over and over until it runs again.
03-04-2016, 08:48 PM   #3
QuoteOriginally posted by LeDave Quote
Well the screw drive niose wont bother me, i hear its faster anyways. I bought the lens used two years ago
03-04-2016, 11:51 PM   #4
QuoteOriginally posted by BirdDude007 Quote
Can you still focus manually?
03-04-2016, 11:54 PM   #5
johnmflores's Avatar
This worked on my 16-50...
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/300459-foun...ml#post3548232
03-05-2016, 01:03 AM   #6
ChatMechant's Avatar
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/311609-sal...nversions.html
I have a 16-50 and 300 converted to screwdrive. I can say that the noise isn't as loud as I expected. Whether it's faster or not I can't tell.
03-05-2016, 01:23 AM   #7
HYS
Six years ago I let my 17-70 to be repaired (SDM motor exchange in the local Pentax service).
It costed me about $100. Since then the lens works perfectly. I like it a lot.
The 50-135 seems to have this problem very often. I think that the series of the SDM motors are reliable.
03-05-2016, 07:02 AM   #8
rei_vilo's Avatar
I had my SDM 50-135 repaired twice.
The motor seems to be under-sized for the lens and so tends to over-work.
As I claimed this was a defect, Pentax only invoiced me part of the cost, either the service or the parts, I can't remember.
Try moving the focus first manually, and then with the motor. Maybe the protective joints are getting harder when not used for a time.
03-05-2016, 07:57 AM   #9
QuoteOriginally posted by johnmflores Quote
Wow!!!!! That worked like a charm! Thanks! I am still thinking of having it converted to screw drive....seems more reliable that way
03-05-2016, 08:02 AM   #10
csa
csa's Avatar
If you don't wish to convert it yourself; a member here does this very reasonably!
(I'm not associated with this member, simply glad someone does this for the membership)
03-06-2016, 09:06 AM   #11
slip's Avatar
That might fix it for a while but at one stage it just won't wake up
I would do the conversion as others (including myself) have done.
Good luck
Randy
03-11-2016, 05:53 PM   #12
I'd be interested in knowing that as well. I've only recently had experience with SDM and was totally unaware that at least sometimes when the SDM files, the manual focus ring completely decouples (basically operates in permanent "soft stop" mode), leaving the lens completely unusable.
.....sdm in 50-135mm, camera, pentax help, photography, troubleshooting
Help me please regarding DA* 50-135mm F2.8 SDM Caver Pentax SLR Lens Discussion 6 11-19-2015 05:35 PM
For Sale - Sold: SDM Failed Pentax SMC DA* 50-135 goodasgold Sold Items 4 03-29-2015 03:11 PM
50-135 SDM failed again! volosong Troubleshooting and Beginner Help 9 01-08-2014 10:54 PM
DA 16-50 SDM Failed do I return for refund or get repaired fewing1 Pentax SLR Lens Discussion 9 01-31-2013 09:07 AM
For Sale - Sold: DA*50-135mm with failed SDM farfisa Sold Items 23 08-27-2009 05:05 AM
All times are GMT -7. The time now is 05:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
