03-05-2016, 05:59 AM   #1
pink cast on my Pentax SR
Recently my photos started having a very bright pinkish cast to them. If the camera sits overnight undisturbed it will take several great photos and then the cast appears again. Camera is only one year old. Please help.
03-05-2016, 08:21 AM   #2
Sounds like a white balance problem. I suggest you check that your white balance is set to auto. It is fairly easy to accidentally change white balance with the 4way control pad on the back of the camera. It has happened to me... Thankfully I shoot raw, so no harm done in the end. Good luck.
03-05-2016, 08:30 AM   #3
amoringello's Avatar
Are the actual images that color or just the screen?
i.e. when you download the images off the car to your computer do they still have the color cast?
If the camera sits overnight and is fine for a short while, it sounds like it could be an electronics issue.
But it could be just the display, as annoying as that might be it is not as bad as if the photos are actually stored that way.
Secondly, does this happen with different SD cards? Wonky SD cards can cause odd effects.
If it isn't a white balance issue, and the SD card(s) are fine, I think you may need to send it in for service.
03-05-2016, 12:27 PM   #4
needs service
The whole screen has a pink cast. Probably will need to send it in for service. Not the card. not the white balance either. thanks for your input
camera, cast, pentax help, pentax sr, photography, photos, pink cast, troubleshooting
My K3 locked up with pink artifacts can't turn off/on enyceckk Pentax DSLR Discussion 4 02-22-2015 05:21 PM
Pentax k3 live-view noise jerk normal? Tested SR on and off... NW_Legacy Pentax DSLR Discussion 2 02-12-2015 10:28 PM
Pentax HD PENTAX-DA645 28-45mm f/4.5 ED AW SR Lens listed on B&H fap Pentax Medium Format 20 08-05-2014 03:31 PM
Blue cast using M prime lenses on K500 martbev Welcomes and Introductions 11 06-23-2014 04:07 PM
I miss the SR switch on my K20D stormtech Pentax K-5 14 03-09-2012 01:41 PM
All times are GMT -7. The time now is 09:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
