Originally posted by Not a Number Mount the lens and with the camera off look through the front of the lens. Is it wide open (normal operation) or closed down (something is wrong)?
If I have the Lens in my hand and turn to f22 the aperture is closed. In the moment I put it back on the camera the aperture will open up wide as you describe "normal operation"
Originally posted by stevebrot are you sure the lens is fully mounted on the camera?
Hello Steve, I double checked this and I am quite sure I mounted it correctly.
Originally posted by UncleVanya The green button is NOT wide open metering.
I know that. What I meant is that the metering is working on the K1000, so that there should be at some point any adjustment that delivers information to the kamera (e.g. the lever is moving and working and the lens seems to be ok on the film camera ).
You guys have serious insight! Thanks for your help! Deeply appreciate it. Do you have any other ideas what this could be?
I attached to other shots of that lens. one is showing the 12 o'clock when mounted.
