03-12-2016, 12:28 PM   #1
Extension Tube K 3
When I screw on the extension tube everything becomes very dark, so that I cannot see what I am looking at, I am using a DA lens with either one or three tubes attached
any suggestions. These are just basic tubes.
03-12-2016, 12:35 PM   #2
QuoteOriginally posted by DR.DN Quote
Welcome to the Pentax Forums!
That might be your problem. Do your tubes have the actuator coupling for aperture (lever on back of mount)? Without that your DA lens will be fully stopped down when mounted rather than fully open. Note too, that unless the tubes have contacts on the base, you will be limited to shooting wide open with lenses lacking an aperture ring.
03-12-2016, 12:47 PM   #3
Not a Number's Avatar
If they are cheap tubes without an auto-aperture lever or a catch for the lever on the lens the lens would be stopped down.
03-12-2016, 12:55 PM   #4
Yep...thanks for catching the ambiguity in my reply. With DA lens, no lever = always full closed. Lever, but no contacts = always full open.
03-12-2016, 01:53 PM   #5
Thanks for both replies , Yes it looks like the answer to my problem, any suggestions to a good extension tube set
03-12-2016, 01:54 PM   #6
mcgregni's Avatar
I had the same problem recently with my flower shots, and I wanted to shoot f9.5 - f11, making focussing in the dim indoor light impossible. The actual exposure was no problem due to the use of flash , but I used my AF-540FGZII flash solely for its LED lamp to illuminate the flowers for focussing at the stopped down aperture ..... You can see the images plus the equipment here ....
https://www.pentaxforums.com/forums/12-post-your-photos/316233-macro-roses.html
03-12-2016, 02:03 PM   #7
UncleVanya's Avatar
But some cheap a series teleconveters, remove glass.
camera, extension, extension tube, k 3, pentax help, photography, troubleshooting, tube, tubes
For Sale - Sold: Pentax Helicoid Extension Tube K in original case gdneil Sold Items 13 09-12-2016 08:32 AM
For Sale - Sold: Pentax Helicoid Extension Tube K oneill Sold Items 5 03-24-2016 12:52 PM
For Sale - Sold: Pentax Auto Extension Tube Set K oneill Sold Items 5 03-14-2016 04:08 PM
K mount to M42 extension tube ntrao Pentax Camera and Field Accessories 21 09-02-2015 04:12 AM
For Sale - Sold: Pentax Helicoid Extension Tube K baro-nite Sold Items 3 04-04-2015 05:35 PM
All times are GMT -7. The time now is 06:20 AM. | See also: NikonForums.com, part of our network of photo forums!
