03-28-2016, 01:53 PM   #1
sholtzma's Avatar
problem with white balance check
When I turn on my K-5iis, which has images on the SD card, and I then press the WB on the 4-way controller, it does not pull up the last image taken. Instead, I get a black background. The WB controls show and are operable. But I can't use the controls on an actual image. What am I overlooking?
03-28-2016, 01:57 PM   #2
enoeske's Avatar
QuoteOriginally posted by sholtzma Quote
If you turn the camera off, it clears the buffer. You have to have a fresh shot in the buffer for it to show the real time WB changes.
03-28-2016, 02:12 PM   #3
Yup, these settings are just for future images that will be captured. The screen should allow you to capture a test image for the purpose of WB adjustment, however.
03-28-2016, 03:19 PM   #4
sholtzma's Avatar
Got it. thanks.
camera, controls, image, pentax help, photography, troubleshooting, wb
K3 Auto white balance problem lotech Pentax DSLR Discussion 7 08-04-2015 07:15 AM
flash white balance problem adwb Flashes, Lighting, and Studio 3 03-13-2012 08:47 AM
K100D white balance problem smf Pentax DSLR Discussion 3 06-07-2010 04:45 AM
White Balance Problem lectrolink Pentax DSLR Discussion 16 05-30-2010 03:16 PM
Manual white balance problem with K20D. DJP Pentax DSLR Discussion 2 11-01-2008 02:39 AM
All times are GMT -7. The time now is 12:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
