03-31-2016, 01:02 PM   #1
Memory card issue K10D
Hello,
I'm (was ?) the happy owner of a K10D since 6 years. I never had an issue until recently.
I never had any issue until recently when I started to get a "memory card error" notice or "the image couldn't be taken" (not sure if it's the exact translation).
I've tried two different cards : an 32 GB Emtec Card (class 4) and a 8GB Kingston Card (class 4 also). The problem stay the same in both situation.
I've already tried formatting cards both through computer and camera. I also already updated the firmware (ver 1.31). The problem stays the same.
I'm currently in the middle of nowhere (south Ecuador) and I need my camera to work as I'm here for a job.
Any ideas ? Thanks
03-31-2016, 01:25 PM   #2
wtlwdwgn's Avatar
Check to make sure the cards are not locked as I've had that the cause of the error before. If not, the cards may be corrupted.
03-31-2016, 01:32 PM   #3
After this message, I tried with a few more cards I've, including smaller ones because someone told me the K10D had occcasional issues with more than 4GB memory.
Problem is the same. (and they're not locked either).
Thanks anyway
03-31-2016, 01:32 PM   #4
Maybe the cards have gone bad? I'd try to buy a sandisk card (class 10 or better) if you can, and test the camera with that. Also, make sure the write protection pin isn't engaged on accident.
03-31-2016, 01:44 PM   #5
blackcloudbrew's Avatar
Make sure there isn't a broken piece of plastic in the card reader in the camera. Not saying this is the problem but I had this happen on my Q system and the error messages were kinda like that.
04-02-2016, 03:36 PM   #6
slip's Avatar
Make sure your firmware is up to date first
Good luck
Randy
04-02-2016, 03:46 PM   #7
QuoteOriginally posted by slip Quote
Good luck
Randy
Good luck updating if the camera cannot read a card...just say'in...
04-02-2016, 04:07 PM   #8
Not a Number's Avatar
Version 1.31 is the latest for the K10D.
04-02-2016, 05:49 PM   #9
aleonx3's Avatar
Could it be the problem with the SD slot in k10D camera? It's been working does not mean that it will not fail as it is after all, an old camera.
04-26-2016, 01:11 AM   #10
Hi there.
I've had the same problem with my k10d. It looks like it is a connection problem with the SD card slot.
The problem came and went so I ended up buying another low mileage k10d. It is still a great camera. No bells and whistles but everything you really need in a brilliant easy to use package.
04-26-2016, 02:58 AM   #11
dunearn's Avatar
Try taking the battery out whilst camera is switched on and leave the memory card in .... worked for me anyways
camera, card, cards, class, issue, k10d, memory card issue, pentax help, photography, troubleshooting
Memory Card Issue Pentax K-50 Zoomer Troubleshooting and Beginner Help 6 08-11-2014 06:24 PM
Memory card issue bass3587 Pentax K-5 9 03-15-2013 08:01 PM
Memory Card issue with K10 VTPentax Pentax DSLR Discussion 6 04-05-2010 05:22 AM
K20D Memory Card Issue George Lama Pentax DSLR Discussion 11 11-27-2009 07:32 PM
K10D problem or memory card issue? harv3589 Pentax DSLR Discussion 19 07-16-2007 07:29 PM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
