04-04-2016, 07:03 AM   #1
Pentax 645 and Pentax FA lenses
I have a Pentax FA 45-85mm medium format lens that will only zoom approx 48-63mm on my non autofocus body. Does this FA lens need to be mounted on a newer autofucus body to work properly? BTW it doesn't zoom properly when mounted nor dismounted. HELP!
04-04-2016, 07:07 AM   #2
bertwert's Avatar
QuoteOriginally posted by Franky2step Quote
Sounds like it gets stuck.
Depending on your abilities you might be able to fix it yourself, or have to send it to Eric.
04-04-2016, 07:54 AM   #3
jatrax's Avatar
Has nothing to do with the body. The zoom function should work on or off the body. Sounds like something wrong. I had an old takumar that had the same type problem with the focus ring. Upon opening it up I found a small piece of bakelite inside. I never did find where it was supposed to go. The lens is in absolutely mint condition so I suspect the piece of plastic was in there from the factory jamming up the works.
As Bertwert says, it likely needs a little work.
04-04-2016, 08:47 AM   #4
Thanks, Guys! I had a camera repair guy look at it this morning and he patiently worked it over, changing apertures, manual focus ring in and out, trying to zoom, etc etc. After 15 minutes he got it working, a little sticky but with use it should free up, according to him. Thanks for taking the time to help me through this.
body, camera, fa, lens, pentax, pentax fa, pentax help, photography, troubleshooting
For Sale - Sold: Pentax 645 lenses FA 33-55, A 75 LS, FA 200 yurihuta Sold Items 18 10-23-2015 10:21 AM
Pentax 645 FA lenses rick_reddy Pentax Medium Format 18 12-15-2014 11:40 AM
For Sale - Sold: Pentax FA 24-90 and 645 FA 200mm lenses spartan Sold Items 21 04-11-2012 01:21 PM
Pentax 645 120mm macro and Pentax 645 35mm lenses and Pentax 6x7 45mm lens. Newmoon Pentax Medium Format 11 03-14-2012 02:10 PM
All times are GMT -7. The time now is 02:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
