04-07-2016, 11:53 AM   #1
slip's Avatar
fine focus reset on the Kx
I have a Kx sitting around and I need to try and find out how to get the focus adjustment back to zero.
Anyone know how to reset it in the debug mode?
Thanks
Randy
04-10-2016, 12:13 PM   #2
I don't own a K-x, but I think it does only offer one (base) correction, not corrections for multiple lenses.
If so, the procedure may be somehow similiar to the procedure on the K200D.
If so, you must apply reverse sign corrections as often as needed to set the value back to zero.
Just as an example with a random value set:
To reset an actual correction of -200, and the K-x would only allow for corrections of +/- 50 in one step, you would have to apply a correction of +50, and repeat this procedure three times more.
04-10-2016, 02:55 PM   #3
slip's Avatar
QuoteOriginally posted by RKKS08 Quote
The thing is I don't know how much I initially changed it
Thanks!
Randy
04-10-2016, 03:23 PM   #4
QuoteOriginally posted by slip Quote
If all else fails, one thing to try might be updating/re-installing the camera firmware. That might wipe the debug menu slate clean (unless the camera stores the debug settings in memory somewhere, like it does date/time).
Thanks!
If you take a JPEG photo, then open it in EXIFTOOL, there is a possibility [haven't checked it myself] that the AF debug correction value may be stored somewhere in the EXIF data.
04-10-2016, 06:08 PM   #5
My suggestion as well.
04-11-2016, 02:43 PM   #6
I thought the K-x would at least use the standard of the K200D, which shows the actual correction value.
In my example the actual value is -100.
With the cursor buttons, I selected a modification of +70.
If I now press OK, the new actual value will jump to -30.
Modifications are cumulative. Repeated mods allow for corrections of more than +/- 100.Name:  IMGP5493.jpg
camera, dslr, focus, kx, photography, reset
Fine focus adjustment question Wingincamera Pentax SLR Lens Discussion 13 02-01-2016 06:38 PM
Fine Tune Focus mattieyp3 Troubleshooting and Beginner Help 2 05-11-2014 11:18 PM
Adjusting the fine focus on K-x... GibbyTheMole Troubleshooting and Beginner Help 7 03-06-2014 10:32 AM
lens focus fine on one camera but not another? BethC Troubleshooting and Beginner Help 12 05-20-2013 02:45 PM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 13 11-19-2011 11:32 PM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
