04-09-2016, 11:21 PM   #1
Metz 50 af-1 does not flash
Hi
It's been awhile since I have used my gear and my flash did work about 3 weeks ago, but now it does not. I have tried two bodies (K10D and K5 II), and the green flash light on the flash body is solid, indicating it is ready, but when I press it or even use Manual mode it does not flash. I have used fresh Eneloops, updated firmware to V4, and have also done a Reset. One question I do have is that I see a "brown" line to the left of the tube in the flash (see attached). Is this normal? I suspect my bulb is burnt out. Any help or advice is much appreciated
PENTAX K-5 II  Photo
04-10-2016, 12:16 AM   #2
If the flash doesn't fire when you press the test button, I'd say either the bulb is burnt out or there's some other problem with the flash's circuitry.
04-10-2016, 01:55 PM   #3
My Metz 50 works well and also has brown line
PENTAX K-30  Photo
04-10-2016, 09:23 PM   #4
Can you hear the capacitor charge? I can't seem to hear it. I'm from Canada, so I've contacted Amplis to RMA my flash. I'll probably go ahead to repair it for less than $150.
04-11-2016, 05:40 PM   #5
I also do not hear the capacitor charge. Good luck
04-11-2016, 05:56 PM   #6
Thanks for all the feedback and help. I hope it is simply a bulb replacement. It better be less than $150
04-27-2016, 02:22 PM   #7
Update: dealing with the service center has been a very efficient and good experience thus far. The initial assessment points to a new flash bulb is required and I approved to try replacing it. If it works, the repair will be less than $100 all in, much better than a new flash unit with P-TTL (appx $400 for the latest comparable Metz). On a side note, although fully manual, my experience with Yongnuo 560 III has been very good. I purchased it while waiting for my Metz to be repaired.
camera, flash, metz 50 af-1, pentax help, photography, troubleshooting
For Sale - Sold: Metz mecablitz 50 AF-1 flash David L Sold Items 2 05-07-2015 10:57 PM
For Sale - Sold: Metz 50 AF-1 Flash brofkand Sold Items 2 05-23-2012 12:14 AM
k-5 does not transfer data to metz 50-1 txhills Pentax K-5 6 05-19-2012 08:42 AM
Wanted - Acquired: Metz 50 AF-1 Flash amber waters Sold Items 4 04-19-2012 07:15 PM
For Sale - Sold: Pentax 18-55WR and 50-200WR, Metz 50 AF-1 Flash dgaies Sold Items 4 08-08-2011 06:11 AM
All times are GMT -7. The time now is 03:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
