Originally posted by pentytaxy Inside of the lens is crystal-clear. :\ The technician is trustworthy, but he says the photos might be overexposed, as evident in the outdoors shot up there. Could it be?
It's not overexposure because some of the pics you posted were just fine...or maybe even a half stop under. By any chance are you hopping out of an air-conditioned car into warm, moist locations right before you shoot? That could cause condensation to form on elements of your lens, but when you check it later, it would be gone.
Quote: And suddenly, my shutter button is stuck. No film, just winded crank, and the button is stuck depressed. The mechanism isn't firing.
Sometimes the wind lever hasn't quite advanced far enough to re-cock the shutter. Since there's no film in the camera, push the rewind button on the bottom of the camera and see if that'll let you wind the shutter a touch farther. That may get things back to normal. The other possibility could be that your battery is dead. However, I think the MEs have one mechanical shutter speed so I doubt that's the problem.
