Originally posted by mcgregni Thanks, I'd wondered about that. A bit puzzled though .... is it really helpful or intuitive to have one main 'priority', but then to have two other parameters changing around it with seemingly no control over which one moves each time ?
I can understand ISO changing in TAv (when you want to specifically hold an exact aperture and time value, say for a particular DOF as well as some motion aspect), and so the brightness has to be adjusted with ISO .... but is it any use at all in Av and Tv ?
Surely it is better to decide on a fixed ISO that maximises quality depending on the lighting?. Or maybe that decision can be relinquished to the camera sometimes ?
It really depends on the situation and the shooter.
For example:
* If taking pictures of birds far away (with a telelens like 500 mms), I need a fixed aperture (for the minimum DOF and the quality of the lens), a relative high speed and don't care really what the ISO will be (lets say between 800 and 3200). So, fixed aperture, auto-ISO between 800 and 32 and then I can choose between [auto-ISO] or [auto-ISO and Auto-speed]. In the last case the camera will choose automatically and since I use auto-ISO already on high values the speed stays pretty high anyway with the long lenses (since it is within the programmed reach of the body that I use a long lens)
* if making a sports-picture, mostly closer, I don't generally need a fixed aperture so the aperture and ISO can change between borders but I do need to be able to choose a high speed or low speed with a twist of the wheel (sometimes want to choose to see the movement, the other time want to freeze the image).
In generally, depending on the kind of picture you are taking the ISO nowadays with the newer models is so well that for many pictures the ISO is not as important as the other factores (or just take a very fast and heavy lens!) if it stays below 1600 or 3200. At least, for me that is.
With the DA-50 I don't think that there are many situations where you need a real high ISO though. If you close the aperture to far to get a big DOF doing street-photography in the evening with a high speed or something like that the quality will be less due to the small aperture than due to the high ISO.
