04-17-2016, 10:56 AM   #1
reset Hometown
Hello,
I'm new here (obviously). I rarely post in forums and I'm not sure if this is the place to ask a question. But forums always seem to have friendly helpful people so hopefully someone will steer me in the right direction.
I have been using my k-50 for a while am finally getting annoyed at having to adjust the date and time on every photo. Obviously I did something wrong when I just started using the camera without setting the time and date. The only way I can get the correct time of day, is to set my Hometown as Bankok. I actually live in Arizona. How do I fix this?
Thanks in advance
04-17-2016, 11:11 AM   #2
QuoteOriginally posted by ojnabo Quote
Hello,
Thanks in advance
Just move to Bangkok.
Seriously, you should set hometown first, then set the time. And make sure that you're in "hometown" mode (house icon) and not destination mode (airplane icon) under World Time.
04-18-2016, 06:26 AM   #3
QuoteOriginally posted by bar_foo Quote
Thanks for your quick response. I already had tried your suggestion previously and ever permutation I could think of.
Here is my sequence:
I pressed "menu" went to the "wrench tab" Pressed "ok"
Scrolled down to "world time" and changed "home" setting to Denver (closest to Phoenix). Even changed "destination" to New York
Pressed "menu" to get out
Scrolled up to "Date Adjustment" and set the time for 6:05 AM.
The the screen said "Settings Complete"
I pressed the "Menu" button to escape.
Took a picture and my photograph said it was 3:05 PM, not 6:05AM!!!!
I repeated the above and this time (finally) realized that the word after "Menu" was "Cancel" and that "Settings Complete" was ever so slightly highlighted. A slightly lighter blue grey box surrounding white letters on a darker blue grey is not much of a noticeable highlight with a bright desk lamp.
After this revelation I reset the time, scrolled down to "Settings Complete" which then did noticeably highlight and pressed the "ok" button
I took a photo and hurrah, the time was correct but I forgot to change the date.
Although your suggestion lacked the detail I was looking for (also no detail in the manual), it did prompt me to try again. And this time I got it.
Thanks again for your quick reply.
camera, date, forums, hometown, pentax help, photography, reset hometown, time, troubleshooting
Introducing my "Hometown Photography Series" project carrrlangas Welcomes and Introductions 12 11-09-2014 08:10 AM
Abstract My hometown. Kjell75 Post Your Photos! 7 03-29-2013 04:47 AM
People Hometown celebration LucVer Post Your Photos! 6 04-14-2010 05:31 PM
Landscape Hometown Hike nate_b Post Your Photos! 3 12-29-2009 01:58 PM
Landscape Some shots taken in my hometown rustynail925 Post Your Photos! 4 12-08-2009 04:50 AM
All times are GMT -7. The time now is 12:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
