Thanks everyone!
Indeed the lens is not at its best at 16/2.8 but this was a test to see its limits really. Good old M28/2.8 and A50/1.4 give fantastic results with the astrotracer but I like the idea of a AW lens for this kind of situation when dew and/or frost end up covering the equipment.
Originally posted by Ole You shot with the astrotracer running, so the sensor moved during exposure and the corners will therefore be uneven.
I didn't think of that but I guess you're right, during those two minutes the sensor must have moved quite a bit, thanks!
Here's a shot from earlier that night still at 16/2.8. Two consecutive shots of 180 s iso 400, one with astrotracer on and the other off for the foreground. Blended in PSE 14 so everything looks in place.I cropped a bit the sides to avoid the softer parts of the image.
