04-19-2016, 02:42 PM   #1
Kx metering error
Shot some Kx this weekend and a few of the exact framed shots were much darker. These were shot about 2-3 seconds apart but nothing changed except car number. In looking at the EXIF data, the dark shots were at F22/1:4000 while the correct shots were at F9/1:3200? same shot composition...? Most others came out but in looking at the "proof sheet" collection, they exposures are all over the board.
04-19-2016, 02:46 PM   #2
That's a huge jump! Were you in spot metering mode by any chance?
04-19-2016, 03:24 PM   #3
I was in "action" mode to capture 90 mph Indy cars in a turn. Im not sure if any other variables were changed off the action mode.
04-19-2016, 05:24 PM   #4
kiwi_jono's Avatar
Also if more or less of a bright skyline / sun say is in the frame it can make that sort of difference.
I found I had use a lot more exposure compensation on my K-x that I do with the K-5 (which clearly has superior automatic exposure).
Not sure what exposure mode action scene mode uses but it might be centre weighted.
04-19-2016, 08:21 PM   #5
here are a few, tried to keep the composition the same. Any ideas? Is the sun flare in the middle tripping the metering up?
04-19-2016, 08:35 PM   #6
Wheatfield's Avatar
QuoteOriginally posted by pishta Quote
Some EXIF data would be nice.
04-20-2016, 08:52 PM   #7
had to look at originals as EXIF doesnt carry over to google pic links: in order...
f16 1/3200 ISO 1600
f22 1/4000 ISO 1600
f40 1/4000 ISO 1600
f13 1/3200 ISO 1600
04-21-2016, 06:08 PM   #8
Wheatfield's Avatar
f16 1/3200 ISO 1600
f22 1/4000 ISO 1600
f40 1/4000 ISO 1600
f13 1/3200 ISO 1600
Well, that's some exif data. I was thinking what metering mode were you using for that sequence?
04-21-2016, 11:17 PM   #9
mcgregni's Avatar
Doesn't look like that scene mode is coping very well at all. ISO is too high surely for such a bright day? A good time for some more photographer control
I'd suggest you might have better control with Tv mode and a fixed ISO. What about ISO 400, and about 1/1500 sec....? That should bring your automatically set aperture back to better figures, at around F5.6 to F11. You can finely control the shutter speed to freeze the movement or blur a little if you want, the aperture variations won't matter too much. If you find that you can't get things bright enough then you can bump the ISO another stop to 800.
Check the metering mode as suggested earlier also. The multi-pattern mode would be best I think, and help reduce the impact of bright sun hotspots.
04-22-2016, 07:38 PM   #10
Metering was just full auto/scene mode of action. Sorry, no other tinkering with the camera, just grabbed it, set it to action and snapped away. 95% of the shots were correct or close, just a few were terrible. I shot the same event last year with a Fuji S3 and all 250 were perfectly exposed, in P mode. Maybe a little more control as the shutter was a constant in that mode.
camera, kx, pentax help, photography, shot, shots, troubleshooting
KX and the pull-out lever for metering YQG Pentax Film SLR Discussion 10 02-02-2016 08:30 AM
Kx metering 101 for a newbie WA-surfer Troubleshooting and Beginner Help 4 07-04-2010 12:36 PM
Metering Issue Using M Prime (Kx) Iceburg98 Troubleshooting and Beginner Help 21 04-16-2010 11:26 AM
Kx live view metering ? Igilligan Pentax DSLR Discussion 11 01-05-2010 10:01 AM
metering error or moving clouds? arthur pappas Pentax DSLR Discussion 9 06-23-2008 12:53 PM
All times are GMT -7. The time now is 06:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
