04-22-2016, 02:47 PM   #1
Stuck aperture ring
I have an as asahi Pentax m 1:1.4 50 mm lens and the aperture ring is stuck. When I put the lens on the body it opens to 1.4 and stays there. Can I get the lens repaired or do it myself.. I have taken off the silver plate but am stumped after that.
---------- Post added 04-22-16 at 02:49 PM ----------
The aperture ring on my old asahi 50 mm 1.4 is seized. Suggestions please.
04-22-2016, 02:50 PM   #2
Is the ring physically stuck, or does the aperture just not close down when you turn the aperture ring? If it's the latter, then everything is normal- the aperture only gets stopped down when you take a picture.
04-23-2016, 09:10 AM   #3
Mjh
stuck
The ring refuses to budge. It is like it is welded.
04-23-2016, 11:49 AM   #4
osv
i would google the disassembly for this lens, for example
04-23-2016, 02:00 PM   #5
Mjh
stuck a ring
thanks for the video Do you know what the tool he used is called
04-23-2016, 04:06 PM   #6
You probable got the ball bearing which is responsible for the clicking sound jammed in between the aperture ring and the body. Try a small amount of w-40 on a q-t tip and dab it on so it gets in between the aperture ring and the body. after it loosens up take apart and put the ball back in its indent. good luck
04-23-2016, 09:20 PM   #7
mee
QuoteOriginally posted by niceshot Quote
That's my guess too. I wouldn't try to force the aperture ring, you could do damage to the ring. Rather, it needs disassembly and the bearing reseated if this is the issue.
BE CAREFUL when opening the lens as that ball bearing is both tiny and quick to jump out and get lost.
Take this with a modicum of salt, but I'd disassemble on a cloth towel just to ensure the bearing doesn't roll away on you. That is, even if it isn't the bearing that is the issue.
On an aside, does anyone know the specific size of the bearings used in these old M series lenses for the aperture ring?
04-24-2016, 03:15 AM   #8
I don't recall the ball size, but Micro Tools carries several sizes. I got a small number of each from them a few years ago, which lets me trial fit to get the correct one when needed.
04-24-2016, 04:32 AM   #9
kp0c's Avatar
QuoteOriginally posted by Mjh Quote
Spanner wrench
One example : https://www.amazon.ca/Spanner-Wrench-Camera-Opening-Stainless/dp/B00NUPYDP0/...s=lens+spanner
04-24-2016, 07:37 AM   #10
He doesn't need to take the lens elements apart to fix this problem, in fact it is a wast of time for him to do that unless the elements are filthy.
04-24-2016, 09:12 AM   #11
Yes, since the aperture opens when he mounts the lens the diaphragm works freely, so no reason to open the optical head, just the body where the control ring is located. If the diaphragm were frozen from oil glueing the blades together it would take more disassembly.
04-24-2016, 11:45 AM   #12
https://www.pentaxforums.com/forums/114-maintenance-repair-articles/88051-pentax-50
04-25-2016, 11:32 AM   #13
osv
that's coming up as a dead link... it looks like you can remove the screws in back, pull off the chrome mount, and gain access to the aperture ring, watch out for the ball bearing, as others have posted: M50 1.4
if you start doing this with any regularity, you'll want the spanner wrench and proper screwdrivers.
03-30-2017, 03:36 PM   #14
Adam Schwarzschild's Avatar
QuoteOriginally posted by osv Quote
Hey
I got exactly same problem! Did you succeed to unstuck the aperture ring? I can hear the ball moving freely inside, i also think it just need to be set it back on the right place!
03-31-2017, 10:14 AM   #15
Just1MoreDave's Avatar
The video in post #4 shows the ball bearing at 3:50. From 2:50 to 3:13, the video shows removing the mount. You almost certainly can ignore all the parts of the video involving the front of the lens or the optical elements. You should get a JIS #0 screwdriver first, like Moody's #2085, for the mount screws. Phillips screwdrivers are best at making a nice bevelled pit in the screw head, which helps locate the drill bit when you resort to drilling them out later.
If the aperture ring is really stuck like it's welded, it probably won't slide off nicely like in the video. Something wedged it in place.
aperture, asahi, camera, lens, mm, pentax help, photography, troubleshooting
50mm f 1.7 stuck aperture ring Nino123 Pentax SLR Lens Discussion 5 12-01-2011 10:21 AM
Stuck aperture ring on A 50 1.7 petergottlieb Pentax SLR Lens Discussion 9 10-22-2010 07:17 AM
M 50mm/1.7 - aperture ring stuck jzietman Pentax SLR Lens Discussion 12 12-21-2009 12:59 PM
Aperture Ring Stuck on Promura 20mm Asyndeton Pentax SLR Lens Discussion 2 10-02-2009 10:43 PM
Aperture Ring Stuck rickn Pentax SLR Lens Discussion 2 03-20-2009 02:19 PM
All times are GMT -7. The time now is 02:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
