Originally posted by Apet-Sure Can someone explain why this happened?
I will give it a shot...
Originally posted by Apet-Sure After mounting the lens, I turned on my K10D and set the ISO to 400. It was a sunny day but I anticipated shooting a fair amount at the 200mm end of the zoom and wanted fast shutter speeds.
If you need a particular shutter speed, I would suggest using Tv, M, of TAv mode.
Originally posted by Apet-Sure Now, I don't remember if I changed from Manual mode to Av mode before or after I changed the ISO setting to 400.
Av mode???
Using ISO to constrain shutter speed in Av mode works only as well as your diligence in monitoring the EV warning in the viewfinder.
Originally posted by Apet-Sure When I get back the EXIF says they were all shot at ISO 1000! I've set the camera up to warn me if it tries to go above 800, but Av mode shouldn't be arbitrarily changing my ISO setting anyway should it?
It will if you are set for Auto-ISO or not in Av mode (TAv or green perhaps?) or switched from USER mode*
Originally posted by Apet-Sure All of the shots were overexposed.
Several possible causes:
- Exposure compensation set to overexpose
- M mode with wrong exposure set
- Any mode where the amount of light exceeds available exposure automation. For example: Av mode with aperture set to f/2 and ISO = 400 in full sun. In that example the display will blink, but allow the photo to be taken anyway.
Originally posted by Apet-Sure The lens was a Tokina 80-200mm SZ-X
This might be a clue. Is there any chance the aperture ring was off the "A" position? In which case, (assuming aperture ring is enabled in the settings menu) the camera will default to Av with the lens wide open unless in M mode.
Hmmmm...no definitive answer. Can you provide an example image with full EXIF intact?
* There are other possibilities, but I don't have a K10D in front of me and it has been a couple of years since I last shot with one. That being the case, I won't speculate.
