Originally posted by i5_david Any help deeply appreciated
If you watch carefully you see a little gap in the outer ring. Can this do the trick!?
a lens spanner wrench on those two notches looks like it would unscrew the front lens group, but what you want to do is to remove the front piece of glass, how is that held into the lens group?
the photos seem to suggest that there is a round ring holding the front piece of glass in, i've seen that with some minolta lenses, with those lenses you can unscrew the ring from the lens group, it's only hand-tight, and the front piece of glass will fall right out.
