05-02-2016, 05:20 AM   #1
SR setting, vintage FF lenses
Hi - just a quick question. When I use a vintage manual or A lens on my KS-2, the camera asks me for the focal length so that shake reduction is correct. Do I enter the actual focal length of the lens, or (since I'm using an APS-C sensor with a full frame lens) do I multiply by 1.5? Any help appreciated!
05-02-2016, 05:25 AM   #2
MarkJerling's Avatar
QuoteOriginally posted by babywriter Quote
I've seen varying advice for this, but the concensus seems to be - Simply enter the actual focal length. In the case of a zoom lens, enter a value half-way between the upper and lower length. So, for a 35-70mm lens, 50mm entered will be OK.
05-02-2016, 05:31 AM   #3
TaoMaas's Avatar
QuoteOriginally posted by MarkJerling Quote
True. If it's an APS-C camera asking for the focal length, it doesn't care about the "crop factor"...it just wants to know what lens you've mounted on your camera.
05-02-2016, 09:03 AM   #4
Awesome. Thanks!
05-02-2016, 09:40 AM   #5
QuoteOriginally posted by TaoMaas Quote
Yep. And if you upload your photos to Flickr or some other image sharing site, the focal length will frequently be displayed, so you want that to reflect the actual lens you used inasmuch as you can.
05-02-2016, 02:28 PM   #6
Moderator PEG Judges
Kerrowdown's Avatar
Set the actual length, that way it also keeps the metadata correct too.
camera, length, lens, pentax help, photography, troubleshooting
For Sale - Sold: Vintage Asahi Binoculars 6x25 Jupiter Sr (reduced Oct 17) vonBaloney Sold Items 4 10-19-2012 02:53 AM
Can FA Lenses Cover FF Dimension + SR Movement Distances? cbaytan Pentax DSLR Discussion 14 10-02-2012 08:32 AM
SR setting question OrenMc Pentax SLR Lens Discussion 2 06-27-2008 05:40 AM
Proper SR setting for older lenses Civisi Pentax SLR Lens Discussion 3 06-10-2008 04:02 AM
SR setting modern 3rd party lenses Nesster Pentax DSLR Discussion 4 04-27-2007 12:53 PM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
