Originally posted by Urnamaster13 I am also looking for cheap wide angle lenses for general landscapes. Any suggestions in film-era lens which will work on k-500 ?
Currently i use the kit lens but was thinking i could change to better lenses within budget.
It's a problem, Urnamaster.
A wide angle lens is harder to make satisfactorily than a tele.
From the film era, 24 was considered wide, and cost a bit more so that the 28 was easier to design and cheaper.
Neither are particularly wide on APS-C.
To go under 24mm from that era is making serious compromises in either price or performance.
Maybe you're better off going in a different direction - what about the DA 16-45 on your K-500?
If you've got a little more money and don't mind sending lenses back until you get a decent copy, the Samyang 14mm f2.8 is so good I'll be using it on the K-1 as well.
