05-08-2016, 04:43 PM   #1
Fastback67's Avatar
Flash not firing on K30
This just started a few months ago and has gotten increasingly worse over time, now I'm just frustrated with it.
For whatever reason, the flash is not (usually not) firing when the camera is set to AUTO - TTL mode. It doesn't matter what flash I'm using, the onboard pop up or the shoe mounted Sigma EF-610 DG. It doesn't matter what lens I'm using either, it just won't fire 90% of the time. It gives every indication that it is ready to go, but when you pull the trigger nothing happens... except that the view screen on the back of the camera also goes black and stays that way until you touch the trigger again. If I set the camera to a manual mode (anything other than AUTO) everything seems to be working, although I haven't given it a proper test period.
Another weird thing... if I set the ISO to 100 it works fine every time. Anything higher than 100 however, and it's a no go, regardless of lighting conditions.
At first, it was only giving me trouble with the original18-55 WR kit lens mounted on the camera, but now it doesn't want to work with any of them. Anyone ever have this issue before?
First time in 45+ years of shooting that I've ever had a problem with a Pentax...
P.S.: I have downloaded and successfully installed the latest firmware.
05-08-2016, 06:09 PM   #2
Aaron28's Avatar
clean contacts all around is all I got........
05-08-2016, 08:01 PM   #3
I had a popup flash die on my first K30. First started working intermittently then completely stopped functioning. I was using it a lot to trigger other off camera flashes. It was replaced with another K30 under warranty through KEH, and since then I just bought wireless triggers and save the popup flash for when I really need it.
05-23-2016, 03:01 PM   #4
Fastback67's Avatar
Never did get this one sorted out... The flash works flawlessly in every camera mode except AUTO???
I guess the world may never know...
05-23-2016, 09:43 PM   #5
Quartermaster James's Avatar
#1) Have you tried resetting the camera?
#2) Not a K-30, but I had a flash issue with my K-3. Sent it in for repair. Came back with all new innards and a new build date and actuation count.
05-24-2016, 11:22 AM   #6
Fastback67's Avatar
QuoteOriginally posted by Quartermaster James Quote
I downloaded and installed the latest firmware, but that's about it... this also did nothing to improve the situation.
I cleaned all of the contacts as well, but again, no improvement.
auto, camera, flash, lens, matter, mode, pentax help, photography, time, trigger, troubleshooting
Speedlight flash not firing at fast shutter speeds?? genesmasher Troubleshooting and Beginner Help 25 01-12-2016 10:15 AM
Sigma EF-610 Super not firing on K3 iikamrii Troubleshooting and Beginner Help 3 06-13-2014 06:52 PM
AF400FTZ flash not always firing on K30? stillshot2 Troubleshooting and Beginner Help 13 02-21-2014 04:47 PM
Off-camera flash not firing molotschna Troubleshooting and Beginner Help 19 04-20-2012 02:46 PM
Flash Not Firing smitty Pentax DSLR Discussion 2 11-11-2007 05:28 PM
All times are GMT -7. The time now is 05:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
