06-18-2016, 01:16 PM   #16
The exif is strange, 1.2 megapixels? Also, was the camera in manual exposure?
06-18-2016, 01:51 PM   #17
UncleVanya's Avatar
QuoteOriginally posted by niceshot Quote
no it is the dreaded diaphragm block failure that plagues this model, some guys on this forum will tell you it is perfectly acceptable. I wonder if it happen to them if they would sing the same tune
In doubt that. When that happens the exif doesn't say f22 it shows a much more wide open apeture. The fault appears to be the way the camera is set.
06-18-2016, 04:39 PM - 1 Like   #18
BigMackCam's Avatar
QuoteOriginally posted by RedSky Quote
I had a post up asking if all DSLRs did this, and it was taken down.
@RedSky - only your multiple postings were taken down. One of your threads remains HERE - is this the one you're referring to?
aperture, auto, camera, f/22, focus, iso, liveview, pentax help, photography, troubleshooting, viewfinder
Aperture blade defective? or normal? DA*16-50 MegaPower Pentax SLR Lens Discussion 11 12-09-2013 12:09 PM
Pentax K-R defective ViewFinder or Mirror? mynewkr Pentax K-r 17 12-08-2010 11:32 PM
K-7: loose memory door? Normal or defective? AirSupply Pentax DSLR Discussion 3 03-05-2010 11:11 PM
Defective Camara or Battery Problem K200D?? ganarask Pentax DSLR Discussion 13 02-14-2010 03:27 PM
Defective DA* 50-135mm? lripplinger Pentax SLR Lens Discussion 13 09-15-2008 10:25 PM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
