05-10-2016, 04:44 PM   #1
M42 original adaptall mount and KS-2
I picked up an original Tamron adaptall lens (135mm, f2.8) today with a first generation m42 adapter on it. I can't get it all the way on my KS-2 because of a protruding gear that scrapes against the body overhang above the lens mount. Can I grind down the gear cover enough for it to fit? Should I try to find a different adapter? Would an adaptall-2 K mount adapter work? I have one of those. Ideas appreciated!
05-10-2016, 06:22 PM   #2
Otis Memorial Pentaxian
That is not a straight M42 adapter and is fairly rare. IIRC, it is designed to allow open-aperture metering on the Pentax ES and similar cameras as with the SMC/S-M-C Takumar lenses.
FWIW, neither the regular adaptall nor the one you have will work with your K-S2 without modification. There is no A/M switch to allow full manual operation.
05-10-2016, 08:33 PM - 1 Like   #3
Thanks for the insights. You're right; it's marked for the Pentax ES. Strangely enough, though, the lens does have a manual/auto setting - so I think that, if the adapter had screwed on without hitting the overhang, it might have worked for that particular lens.
Now that I'm home, I've tried the PK adaptall-2 adapter on the lens and it works wonderfully. So I'm happy about that.
Maybe I'll try to sell the ES adapter on the Marketplace - see if anyone wants it.
adaptall, adapter, camera, gear, ks-2, lens, m42, m42 original adaptall, pentax help, photography, troubleshooting
Tamron Adaptall 2 and pentax m42 es Johndav General Photography 6 01-29-2016 06:52 AM
For Sale - Sold: Tamron Adaptall-2 24mm F/2.5 Model 01B with M42 Adaptal mount woof Sold Items 2 09-28-2012 03:53 AM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
