05-19-2016, 11:49 PM   #1
AF button Pentax 20D and Shake Reduction
When I originally set up my Pentax 20D to handle manual lenses some websites recommended that you turn the Custom Setting 13 AF Button Function to 1 (Enable AF). I have been using this setting for months to get an auto focus on the subject matter. The other day when I was pressing the shutter button to half way to focus on the subject matter, I wanted to activate AE-L at the same time, I noticed that the Shake Reduction hand appeared. If on the other hand I pressed the AF button to get focus then quickly pressed the shutter button, in one continuous movement the Shake Reduction hand did not appear.
My question is. By using this fast method of pressing the shutter after obtaining focus with AF button does Shake Reduction not work? This can lead to camera shake blurred images at slow shutter speeds. Is my thinking wrong and does Shake Reduction work anyway once focus has been confirmed.
05-19-2016, 11:59 PM   #2
I believe SR operates at the same time as the meter does. So I think the solution here would be to extend the meter time in the menu, or simply keep the shutter button half-pressed while you're focusing.
05-21-2016, 08:00 PM   #3
Thanks for the reply. I notice that the hand appears after a few seconds, I will just have to slow down.
af, af button pentax, button, button pentax 20d, camera, focus, hand, pentax help, photography, reduction, shake, shutter, troubleshooting
Shake Reduction, both useful and not. pathdoc Pentax K-5 28 08-13-2015 06:45 AM
Manual lens and shake reduction atar Pentax DSLR Discussion 8 10-14-2014 04:37 AM
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 3 06-14-2014 02:51 PM
K5 Foibles (?): Memory card, shake reduction, mode select lock-out button AstroDave Pentax K-5 19 05-17-2011 12:58 PM
K 20D Exif Shake Reduction Info Pedro Pentax DSLR Discussion 3 07-04-2009 02:16 PM
All times are GMT -7. The time now is 07:32 AM. | See also: NikonForums.com, part of our network of photo forums!
