Originally posted by Gabbyp When I press info twice it goes to the screen that displays status screen, toggle right to electronic screen, toggle right to display which indicates display off. At this point when I hit any button the screen goes black as it should, I don't know how to change the display to display on.
You may be overthinking it. Here's what mine does.
Info / Info - gives 4 icons (left most to right: Status Screen, Electronic Level, Display Off, and a compass that I can't engage since I don't have the tracker attachment). If I use the 4 way to move to the Display Off and press OK - the display goes off. If it is already off I get the same choices and I arrow over to Status Screen and click Ok - and now it is on again. The display off is NOT a toggle - it is a status. You can't reselect it to turn it off. Does that help?
