05-23-2016, 09:48 PM   #1
depleted batteries message
Please help me. I have a Pentax K100D (not super), and have had it for several years now. The problem seems to have gotten worse. I have used rechargeable batteries and also alkaline and they have worked, but now I can put in a brand new set of alkaline and it almost immediately reads "batteries depleted". I don't know if there is any kind of a reset or something I can do. Any suggestions? It used to be that I could turn it off and back on and get some more battery life, but doesn't seem to be the case now. Please help, it's still in really nice condition and was hoping to get many more years of use out of it.
05-23-2016, 09:56 PM   #2
QuoteOriginally posted by baboon Quote
Have you tried using a brand new set of rechargeables?
If you do find that there's something wrong with the camera, I'd recommend upgrading to the K-50: you'll really enjoy the image quality
05-23-2016, 09:59 PM   #3
Jonathan Mac's Avatar
My K200D had a lot of problems with AA batteries too. The best solution I found was to use Lithium ones. They're expensive but last for ages and have the advantage of being lighter than other AAs.
05-24-2016, 01:10 AM   #4
IgorZ's Avatar
I have the same problem with mine. I got a K-5 when the problem started, but I would like to fix the 100D for my son...
05-24-2016, 01:34 AM   #5
I had a similar problem with a K100D Super, after months of inactivity due to K-5 purchase, I put the batteries back in and the camera showed low battery, I put fresh lithium batteries in and it still showed low battery. I immediately wanted to go back to the shop as at 7 for 4 Lithium batteries I was unhappy. Luckily I persevered, cleaned the battery contacts as best I could, inserted the batteries again and voila, indicator showed full battery. Camera ready to loan to my Nephew's wife.
However, a week later, after leaving the batteries in the camera, when I loaned it to her, on start up it showed low battery again....taking the batteries out, re-inserting then gave a full battery indication. Weird!
My recommendation is to fiddle about with it, you may get the same result that I did.
05-24-2016, 07:34 AM   #6
Not yet. I have a new set of Panasonic eneloops on order with the charger. I will see what they do.
05-31-2016, 07:08 PM   #7
I had the same problem with my ist DS and my K200D, I see its a capacitor problem . I bought eneloop batteries and Lithium's but it made no difference. I have seen on the net that the Pentax cameras with external power points will run with an external power pack. I keep away from Pentax AA only cameras. My K200D only has 2000 shutter count.
06-02-2016, 01:16 AM   #8
Thank you all for your suggestions. Just one more question - Using the 6.5V DC plug in on the side of the K100D, is there an external battery I can hook to that and use instead of putting batteries in the camera?
batteries, batteriies, camera, depleted, pentax help, photography, troubleshooting
Battery Depleted, Flashing Light SamC130 Troubleshooting and Beginner Help 2 01-22-2016 03:36 PM
K 30 integrated flash causes battery depleted error perplexed Troubleshooting and Beginner Help 5 12-11-2014 12:15 AM
Battery Depleted with new batteries ckoehler Pentax K-r 6 05-05-2013 12:24 PM
"Battery Depleted" message when using Rechargeable AA NiMH gipps_amat Pentax K-r 10 10-31-2011 02:15 AM
depleted batteries wipe Troubleshooting and Beginner Help 9 01-26-2011 05:58 PM
All times are GMT -7. The time now is 06:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
