05-27-2016, 06:57 AM   #1
K5 LCD screen
Hi there
Sometimes (rarely) but happens, when I switch ON the camera the LCD on the back the colors are gone and and its showing all grey colors.
The content of the screen isn't as sharp at than before.
I must turn it OFF then ON again to have the colors back to.
If someone could tell me what is happening I would be very pleased.
Cheers
05-27-2016, 12:49 PM   #2
Could the beginning of a failing main board, damage due to water ingress, or just a loose connection to the screen.
05-27-2016, 10:41 PM   #3
Thank you for you're answer.
The K5 has never been exposed to water, so perhaps a loose connection might be the culprit.
This weird behavior arrived perhaps less than 10 times since I bought it in 2011.
To your point of view, Is this reparable at reasonable cost if it get worse, or will it be the end of the K5 ?
Cheers
05-28-2016, 12:28 AM   #4
QuoteOriginally posted by ide508 Quote
Cheers
If the main board has to be replaced, you'd probably be better off replacing the camera. However, if it only happens intermittently and if it's been happening since the start, it could very well be a loose connection.
camera, colors, dslr, k-5, k-5 ii, k-5 iis, k5, k5 lcd, lcd, pentax k-5, screen
K50 LCD screen shut off question Zerv Troubleshooting and Beginner Help 4 03-26-2015 04:43 PM
K5 LCD screen pixelates tas 0425 Troubleshooting and Beginner Help 2 03-02-2013 05:45 PM
K5 lcd screen dimensions in millimeters? pakinjapan Pentax K-5 3 09-20-2012 11:51 PM
K5 LCD screen weirdness Pelham Troubleshooting and Beginner Help 6 01-16-2012 06:24 PM
Does Kr use same LCD screen as K5 and K7? texoma Pentax DSLR Discussion 7 01-24-2011 12:15 AM
All times are GMT -7. The time now is 03:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
