K3ii weather seal at power button failed
Howdy folks;
I had my K3ii out in the rain for a couple hours last winter.
When I got home I dried it off. Then it wouldn't turn off.
Clearly something was up with the power switch.
After several more tries, it finally turned off but wouldn't turn back on.
So I let it sit for a month - I didn't put it in desiccant.
After a month, the power switch began to work properly. All is well.
Ah, but no. Now if I leave a battery in it, it drains out in a day - with the power off.
The easy solution is to not leave a battery in when not in use.
But I'm seriously considering sending it out.
