Originally posted by Adam Did you zoom a lot while the camera was wet? Because the 18-135mm does not zoom internally, it's possible for water to enter through the lens if you are persistent enough.
Also, were any of the flaps that cover the camera's ports/terminals dirty or not closed all the way?
Try putting the camera in a bowl of rice to suck out the moisture.
If that doesn't work and if your camera is still under warranty I would see if you could get it repaired for free. Definitely worth a shot.
I did use the zoom a lot I didnt notice any moisture in that area, those seemed to be the only seals that held.
The rain really was not bad yesterday thats why Im so surprised it failed at so many points, unless the water came in the cards and leaked else where. When it first acted up I just thought the battery had gotten to cold, and after trying it for five minute this morning the only thing that may power on is the gps light now. Even if they do cover it Ill be too afraid to use it in any kind of weather for more than a couple minutes now because really it basically had a light coating of rain drops on it yesterday my hands did not even get wet enough to prune up. Ive read some peoples stories about they holding up to heavy heavy rain for a decently long period of time so I never would have imagined a few hours hiking would take it out. Ill try the rice and update with what ever the rice (probably way too late) or ricoh does.
