Originally posted by mcgregni The camera AF assist light needs to be switched off in your camera settings. Then use the 'SB' (spotbeam) mode on your flash, accessed via the mode button.
You are right, the
AF Assist Light in K-3 menu has to be switched-off.
What is more:
* While in-camera focus-assist light operates when in
Live View, the flash-unit near-infrared spot-beam does NOT assist when
K-3 is in it's
Live View;
* Autofocus mode has to be set-up as
Single (
AF-S);
K-3 shooting mode might be in
Continuous Shooting mode;
AF-540FGZ settings overide in-camera
K-3 body settings (
slow speed / trailing curtain sync);
* When
K-3 is in
Live View, one cannot set
AF-540FGZ flash metering mode to
Auto nor to
Manual, but you can set AF-540FGZ
Auto metering mode before you switch
K-3 to
Live View;
* Some of the AF-540FGZ modes are not accesible when
K-3 AE metering (
incl. AE-Lock) is engaged.
Actually, it's a little bit weird (
and AF-540FGZ manual does not cover K-5 nor K-3 bodies).
