06-12-2016, 01:40 AM - 1 Like   #16
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by bessa-66 Quote
Aaah, but you're not a glass tube!
I've been called the last word there on occasion.
06-12-2016, 10:25 AM   #17
Not so with the 300... it does stick when I press it down off the camera- is there any chance that this can be fixed with a little oil or something?
I would hold off on the oil. It is probable that something inside is bent and jamming. It is probably fixable, but some disassembly would be required.
06-12-2016, 11:08 AM   #18
Quartermaster James's Avatar
^^^^ What he said.
In your adventures into amateur lens repairs, you get to ruin* one lens by oiling the blades. It's the price of experience. Choose this lens wisely.
*okay, it's not permanently ruined, but it takes a lot of cleaning to recover. There's a reason "no oil on the blades" is often included in descriptions of used lenses.
Contact Eric Hendrickson http://www.pentaxs.com/ if you are interested in having it serviced.
06-12-2016, 03:46 PM   #19
QuoteOriginally posted by Quartermaster James Quote
^^^^ What he said.
Contact Eric Hendrickson Home if you are interested in having it serviced.
Haha yes, lens DIY can be risky! I declicked an old lens once completely by accident.... Lucky it only cost me $5! 😂😂
06-12-2016, 09:38 PM   #20
Analogy: You are trying to merry an 90 year old man to a 20 something woman. Nice, but...
Isn't it time to lower this old man, err lens into the grave ? RIP
06-12-2016, 10:43 PM   #21
QuoteOriginally posted by Schraubstock Quote
I don't know about that. My M42 300mm f4 works just fine, and it's got to be older.
06-12-2016, 10:57 PM   #22
Perhaps, but it's the only one I could afford! Works fine when the sun is low, on an overcast day and the planet's are aligned! What is the new Pentax equivalent?
06-12-2016, 11:20 PM   #23
SMC Pentax-DA* 300mm F4 ED [IF] SDM Reviews - DA Prime Lenses - Pentax Lens Reviews & Lens Database
06-12-2016, 11:55 PM   #24
Seems like a great lens for the money! Is there a third party equivalent like sigma or tamron?
06-13-2016, 12:24 AM   #25
It was said in jest
06-13-2016, 04:45 AM   #26
It was said in jest
It a all good! 😊😄
06-13-2016, 07:22 AM   #27
Hi Elvinhaak, this lens has no A setting on the ring at all
Of course not, but the body might just 'think' that your lens is in the 'A'-setting because the lens is powdered or making a bad contact with the 'A'-contact on the body.
The system the body notices is simple: if there is a contact present between the 'A'-contact on the body and 'earth' there is a non-'A'-lens on the body or the lens is set to another aperture then 'A'.
If there is no contact on the 'A'-contact, the body knows that the lens is set to an 'A' so that the body controls the aperture.
So: if you don't have a good contact between the lens and the body, the body calculates that your lens is an older 'A'-lens and thus would try to set the aperture itself .Since it cannot connect digitally to the lens, it stays open.
I have experience with this ... had to sand my lens to make contact on the 'A'-contact and the problem was solved.
06-13-2016, 07:23 AM   #28
It was said in jest
Ach! Sorry! Color me dull!
---------- Post added Jun 13th, 2016 at 06:26 AM ----------
If you're open to a zoom, give this a look: HD Pentax-DA 55-300mm F4-5.8 ED WR Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
06-13-2016, 08:22 AM   #29
QuoteOriginally posted by elvinhaak Quote
Other way around for the "A" contact. What you are describing is related to the "data" pin*. The camera will test for continuity between that pin on the body and the lens mount as a means of telling whether a lens is mounted and will gate some functions based on the result.
* The "A" pin is at position #3, while the "data" or "digital contact information" pin is at position #7 See article HERE
06-13-2016, 03:11 PM   #30
Does the 300mm give a 400mm field of view on the Kx even though it's a DA digital lens?
aperture, aperture lever, body, camera, change, circle, contact, frame, image, lens, lenses, lever, lifeview, pentax, pentax help, photography, post, press, reviews, troubleshooting
What are these lens for ? redcat Pentax SLR Lens Discussion 24 11-29-2014 06:22 AM
Nature What kind of bees are these? charliezap Post Your Photos! 5 07-22-2014 05:45 PM
What are these purple spots broah Pentax K-5 3 04-09-2012 09:38 PM
Anybody know what causes these artifacts and what they are called? BPT Photographic Technique 17 01-05-2008 12:11 PM
What are these red marks in the leaves, K10D? WildSioux Photographic Technique 29 06-23-2007 12:35 PM
All times are GMT -7. The time now is 08:29 PM. | See also: NikonForums.com, part of our network of photo forums!
