Originally posted by Nass I kind of disagree with Adam I'm afraid, I think that a K7 and 40mm lens for $300 is a much better deal than just a body for $400. Sure, K7 isn't the latest and greatest but for 95% of photography situations it's still perfectly ok. With the $300 deal you can actually take shots but with the $400 deal you can't, you still need to buy a lens. Have a
look at this link, it'll show you what you can do with a K7.
Thanks for your suggestion...
---------- Post added 06-22-16 at 01:31 AM ----------
Originally posted by Giklab 1. Don't try using that flash, you may fry your camera.
2. Watch out for the Ricoh pin on that lens, but otherwise it is probably a good lens.
The K-5II is a better camera than the K-7, although you're basically paying 200% more for it. Not sure if it's worth it, can you try and get a lens into that deal?
PS Did you ask this on the on the FB group by any chance?
Thanks for cautioning me regarding Flash, I wont use it.
Yes I also asked the same question on FB page also
---------- Post added 06-22-16 at 01:38 AM ----------
Originally posted by Bruce Clark I have a K-7 and the 400mm lens as well, a great combination. The K-5ii would be a better camera body no doubt. I also have a K-5iis which is a far better camera body then the K-7. The K-7 would be an excellent camera to begin with provided it is in good condition and not too many shutter actuations. Mine has over 55,000 and still going strong.
I also use a number of Ricoh lenses, not that particular model though. As already suggested the "Ricoh Pin" could be a problem. There is plenty of information on this site about the Ricoh Pin. I understand there are two types of pin. One has a rounded end and the other a flat end. A lens with the flat pin can become stuck on the camera as the pin locks into the focus screw drive on the camera body. The round pin does not lock in, at least not in my experience. If you are interested in that lens examine it carefully and do a search for Ricoh Pin on this site. It should be a fairly simple matter to identify the type of pin this lens has. If it has a flat end beware. There are also extensive guides on how to remove this pin from the lens if it is a problem.
Best wishes.
Thanks Bruce for cautioning me of possible problem while using Rcoh lenses but fortunately my lens didn't had any Pin!
