06-21-2016, 05:47 PM   #1
K-x no longer can focus to infinity, any lens
Recently, my K-x has stopped being able to focus to infinity. This happens with any lens I have tried -- DA 18-55mm, and manual focus 55mm, 135mm (which have always been nice and sharp at their infinity stop). It's not very far off -- things look ok in the viewfinder, but when zoomed into the resulting images or with live view, it's definitely not as sharp as it used to be. So I suspect that the sensor has gotten knocked around and now sits a bit farther back than it should. It's the same with SR on or off. Is there anything to be done?
06-21-2016, 05:53 PM   #2
QuoteOriginally posted by frankfrank Quote
The infinity mark on the lens does not always correspond to true infinity. Changes in ambient temperature can cause the actual infinity point to fluctuate over time.
If you're able to manually get the lens to achieve sharp focus while in live view and with a setting other than exactly the infinity mark, then nothing is wrong with the camera. On the other hand, if things look soft, even with the lens stopped down, then your suspicion about the sensor might be right.
06-21-2016, 06:19 PM   #3
There is a focus sensor on the bottom of the mirror box. Clean it
06-22-2016, 12:15 AM   #4
It happens to my k5. Is there any diy to fix this? Clean focus sensor didn't work.
06-22-2016, 02:00 AM   #5
Are you able to do manual focus, meaning does this yield different results?
06-23-2016, 04:49 AM   #6
here's the result with mine when i test with another camera, i think the same thing happen to op
06-23-2016, 11:31 AM   #7
If you have the nerve you can remove the bottom of your camera and there are 3 adjustment screws for the sensor. proceed with caution. having said that did you try manual focus?
camera, focus, infinity, k-x, lens, pentax help, photography, troubleshooting
Question I no longer use PayPal......I no longer accept PayPal.....Can I still sell on PF ?? Dlanor Sekao Site Suggestions and Help 8 04-07-2016 07:38 PM
Focus ring offset or no infinity focus? (Mamiya 55mm F/1.4) Doundounba Pentax SLR Lens Discussion 6 12-22-2015 07:59 PM
Can't focus to infinity on my LX Asudef Pentax Film SLR Discussion 4 08-31-2015 06:12 AM
Pentax K-X Flash No Longer Works Sherry Q. Visitors' Center 2 02-14-2012 08:34 PM
Having no infinity focus on manual lens? clockwork247 Troubleshooting and Beginner Help 17 12-23-2010 04:22 PM
All times are GMT -7. The time now is 09:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
