06-23-2016, 12:13 AM   #1
Double effect with slow shutter speed even with tripod
Hi! First of all my english is not the best but I'll try to explain my problem.
I've păurchased a K200d in the past from a random guy on web and it appears that when I use slow shutter speeds with triopod and correst settings.. whatever I do the pictures come out blured, ghostly or with double effect. It seems I cannot use shutter speeds slower than 1/70 ~ 1/90 >
I've tried many lenses.. same problem and I have to mention that I use mirror lockup function too (image stabilization button is turned off). It can be the sensor missaligned?
In the attachment is a 100% crop from inside. Outside pics.. the same problems.
PENTAX K200D  Photo
06-23-2016, 01:08 AM - 1 Like   #2
mcgregni's Avatar
Are you pressing the camera shutter button with your finger to take the image? This could be moving the camera at the point of capture .... For tripod and mirror up shooting then use a remote control, cable release, or self-timer function so that you don't touch the camera at all ...
It's worth a try to eliminate this issue as the problem.
06-23-2016, 02:25 AM   #3
That's camera movement.
Use the 2 sec self-timer.
It automatically switches off SR for the shot so you don't have to think about it, lifts and locks up the mirror, lets the camera 'settle', then fires the shutter.
Make sure you cover the eye-piece to avoid light entering through it, and use a sturdy tripod.
06-23-2016, 02:57 AM   #4
QuoteOriginally posted by JohnX Quote
Is this true for all (current at least) Pentax DSLRs? I did read before that this setting lifts up the mirror beforehand, but the thing about disabling the SR is new to me
06-23-2016, 05:16 AM - 1 Like   #5
QuoteOriginally posted by ehrwien Quote
As far as I know it's always worked this way. First Pentax DSLR I had was a K100D. I'm sure that did it, but can't swear to it. Definitely has done it from K20D onwards.
06-23-2016, 05:30 AM   #6
You can also have issues with low end tripods. My light tripod works great with a small point and shoot but not my K-3. The head has some flex so when I push the trigger it's enough to make it wobble slightly and the 2 second delay isn't long enough to stabilize.
Try using a remote so you can give it 15-20 seconds to stabilize. If you don't have a remote you can also try setting it on a sturdy table to rule out tripod shake.
blur, camera, double, effect, ghost, k200, pentax help, photography, problem, sensor, shutter, speeds, troubleshooting
Just got an LX.... and slow shutter speed seem way too slow LFLee Pentax Film SLR Discussion 42 07-14-2016 10:23 AM
Shutter speed changes even with AE-L during continuous shooting. geomez Pentax K-01 2 05-31-2013 01:19 PM
People Weight lifter spotting self with the help of slow shutter speed coachteeter Post Your Photos! 3 03-26-2010 10:13 PM
K-x Av with auto-ISO: slow shutter speed issue Karellen Pentax DSLR Discussion 6 02-22-2010 03:58 PM
K-x: question about autopict mode slow shutter speed with flash manteiv Pentax DSLR Discussion 6 01-12-2010 12:39 PM
All times are GMT -7. The time now is 06:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
