07-13-2016, 07:10 PM   #16
QuoteOriginally posted by interested_observer Quote
By chance was the camera pointing up in the sky - with an elevation angle greater than about 45 degrees? If so, there appears to be a design problem where you are pointing high up in the sky that others have found.
The images I posted were of Deneb, and at the time it was around 40 degrees above the horizon, definitely less than 45 deg.. I did get a pretty decent 30 sec. image of Altair a few days later which was lower in the sky and also a lower declination. Unfortunately I have a limited view of the sky with trees and a hillside blocking in some directions. Next time I'll try to get some samples in different directions, altitudes, and declinations.
07-14-2016, 11:33 PM - 1 Like   #17
Grippy's Avatar
QuoteOriginally posted by JimS_256 Quote
Thanks for the response!
I have avoided using longer lenses because I wanted to get the 28mm working first, thinking it would be the easiest. I'll give some longer lens a try too.
I was using the timer for these but I have a remote to use if I ever get the astrotracer sorted out. Looking at my sample images I don't see any signs of vibrartion problems, only poor tracking. At 28mm I don't think this is a big issue but I'll be extra careful if I'm using 200 or 300mm.
Yes the astrotracer symbol and the green GPS symbol show in the rear LCD.
@Grippy What camera are you using?
Sorry for the late reply, I've been away camping.
I'm using a K-50 with mine and have never had a problem with it, once I've done the precise calibration it performs very well, sometimes the calibration takes a while though.
07-23-2016, 02:20 PM   #18
QuoteOriginally posted by Grippy Quote
I appreciate your input. Except for the two sample pictures I posted in the OP all my testing has been with the K3 II and not the K50 + OGPS1. Looking back I seemed to get better results with the OGPS than I did with the K3 II's built in one, which is disappointing since that's the camera I would prefer using. Next chance I get I'll do more testing with the K-50 and see if I get better results.
astrotracer, camera, egg, image, images, k-3ii, k-50, pentax help, photography, star, star trails, troubleshooting, user getting star
Abstract Another night with the astrotracer SunValley Post Your Photos! 5 05-19-2016 09:39 AM
Night Star trails through the light pollution bobbotron Post Your Photos! 2 04-18-2016 06:43 AM
trouble with star trails shed301 Photographic Technique 8 01-27-2016 10:09 AM
K-3 Problem with Star Trails, Interval Mode & MUP DJK-03 Pentax K-3 6 01-26-2016 03:57 AM
Nature Star Trails with subtle Northern Lights tessfully Post Your Photos! 10 09-30-2015 02:13 AM
All times are GMT -7. The time now is 03:41 PM. | See also: NikonForums.com, part of our network of photo forums!
