Originally posted by pbancr Oh and shutter speed does seem to change..tho intermittent...when green button is pressed. Same results when I push the on/off switch all the way to the preview position.
Sounds like it's working as intended, then. The aperture actuator on the K-3 and K-1 is a little bit quieter, so perhaps that's throwing you off.
Definitely do check the exposure compensation setting and metering mode. If you've selected spot instead of center-weighted, that might be the issue.
An easy way to check if stop-down metering is working is to put the camera in live view. If you select a narrow aperture and the DoF increases when you press the green button, then you know everything is ok.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
